72 my project
Discussion in 'General Maverick/Comet' started by classic ccg, May 18, 2011.
  1. Mavman72
    I would weld that brace back to the pan...It will creak/groan if you pop rivit it...
  2. mojo
    If u weld it - Wud u remove the fuel tank?
    If I were going to rivet - I wud just use the rivets to pulley the brace to the pan for the panel adhesive to get a gud grip.
  3. classic ccg
    ringgold GA
    72 maverick
    yes i would drop the tank if i have to but idk what adhesive to use
  4. mojo
    Welding is a lot less expensive but a lot more work. Im considering something like the link I have posted. I have not used this method but I guess it works cuz it's used in the industry.
    http://www.autobodytoolmart.com/lord-fusor-metal-bonding-adhesive-medium-p-15934.aspx
    Im just waiting till it gets warm enough in my part of the country to decide which way im going. If I use this method I will sheet metal screw the brace to the body, bond, paint and leave the screw intact.
  5. classic ccg
    ringgold GA
    72 maverick
    man that stuff is cool i may end up using it and its not bad for te cash :tiphat:thank you for showing me the link
  6. mojo
    Ur welcome. I think it's worth the 60bucks not to have to pull the tank, cover up the interior of the car to give it a try. If it don't work u can still grind the stuff off and do the weld thing.
  7. classic ccg
    ringgold GA
    72 maverick
    ok got some things done now that the maverick a home
  8. classic ccg
    ringgold GA
    72 maverick
  9. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    It's serious i'll be down to pick it up. LOL in Canadian terms thats surface rust!!
  10. classic ccg
    ringgold GA
    72 maverick
    some pics here you go
  11. hotrodbob
    hotrodbob Member
    Central Coast, So.Cal
    Sold my 1971 Grabber
    Lookin good!!!!
  12. classic ccg
    ringgold GA
    72 maverick
    and some good stuff
  13. Bizzness
    Bizzness Member
    71 grabber 351w, c6 ,9" 4.56 locker, subframe, roll cage
    Nice. I see u yankin ur engine out what will u be dropping back In
  14. classic ccg
    ringgold GA
    72 maverick
    a 302 for now but i have a 351windsor
