73 bumper on a 71 maverick
Discussion in 'Parts Interchange' started by noodledood2, Dec 31, 2015.
  1. noodledood2
    noodledood2 Member
    Turlock, CA
    1971 maverick 302
    Is this possible? my 71 has a really beat up bumper and i found a 73 bumper available for purchase. It has the bump gueards but as long as the bracket mounts line up it should work. anyone try this?
  2. 71gold
    I don't see why not...I put a '71 setup on my '73...:huh:
    the fender notch may be the only thing to look a little strange...('73 fenders).
  3. noodledood2
    noodledood2 Member
    Turlock, CA
    1971 maverick 302
    thanks! just wanted to make sure the brackets lined up. figured they would but didnt wanna pull the trigger and be left with a dud...
  4. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    The forward attaching point for the brackets are in different locations. You will have to move it for the 73 brackets to fit. Early fenders have a notch in the front for bracket clearance that 73 and later don't have. The 73 bumper also uses a different lower valence.
    You'd be better off finding a nice early bumper IMHO.
  5. noodledood2
    noodledood2 Member
    Turlock, CA
    1971 maverick 302
    this is regarding the rear bumper correct?
  6. Maverocket
    Northwest
    That is for the front. The rear bumper on a 73 is dimensionally the same as 70-72, the brackets on the 73 push the bumper out another inch or so and have a filler piece that bolts to the end of the quarter panel to fill the gap.
    71 gold mentioned the fender notch so I assumed you were talking about the front, my bad.
  7. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    So the 70-72 don't have a filler piece at all?
  8. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    No. Just a short metal quarter panel extension that some people seem to think is a piece of a spoiler (which it's not).
    The '73 uses a urethane or neoprene extension to fill the gap created by the longer mounts.
  9. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    yes, I'm switching to skinny bumpers, so i just fill in the holes and paint?
  10. Maverocket
    Northwest
    That and installing the little cast piece that fits under the quarter extensions.
  11. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    So, no filling in the holes in order to install the cast pieces. Can't find any cast pieces right now. What are they called?
  12. Craig Selvey
    1970-1972 Lower rear quarter extensions
    NCFatBoy likes this.
  13. Maverocket
    Northwest
    Craig Selvey and NCFatBoy like this.
