73 comet manual to power brakes swap
Discussion in 'Technical' started by Deerhog, Dec 10, 2017.
  1. Deerhog
    Deerhog Member
    Texas
    1973 Mercury Comet GT
    Will a setup from a 75 maverick work and clear the shock tower? I've been reading that s the first year that was available on these cars.
  2. Krazy Comet
    Underhood dimensions are exactly same on all years... The brake pedal assembly is totally different, need the P/B unit and no doubt the brake lines as fitting size differs between year & type of system...
  3. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    I understand 96-o4 Mustangs had hydroboost. Did anyone take a look at that? It basically uses the power brake pump to power a hydraulic cylinder rather than using vacuum. :bouncy:
    MD
  4. Maverick Dude
    Whoops. That should read “uses the power steering pump to power a hydraulic cylinder” I noticed there are brand new kits avaiable. Has anyone adapted one to a Maverick or Comet?
