73 Grabber question: need to verify if floor shift is stock
Discussion in 'General Maverick/Comet' started by 67Mach1, Jan 15, 2014.
  1. Dave B
    It's listed on the regular order form, and not listed as a "Extra Cost", but when you look on the "Trim Availability" chart, it's not listed...I'll have to dig out my trim selection books...:hmmm:
  2. Krazy Comet
    All the special paint code vehicles of the early 70s I've seen are blank, with the Ford code & color listed on the window sticker and build sheet... Sooo AFAIK if a paint code is listed, it's a std option for that vehicle line, popular or not...
  3. Craig Selvey
    That should not be too hard. You are in Texas with lots of rust free cars and parts, plus Texas is a pretty active community of Maverick/Comet people who can help you out.
  4. 67Mach1
    67Mach1 Member
    Round Rock, TX
    1973 Maverick
    you guys talked me into it... Marti report on order.
  5. Krazy Comet
  6. WinterBlue71
    SC
    Did some research and found that 5A Pewter wasn't a special order color, but did find out that special order colors had 6 digit DSO's. Very cool car nonetheless, and I'm glad an enthusiast bought it.
  7. Paul Masson
    1971 Grabber
    Correct! A blank paint code, but 6-digit DSO. Someone on here had a factory-purple Maverick some time ago.
  8. 67Mach1
    67Mach1 Member
    Round Rock, TX
    1973 Maverick
    One of 642 with paint code
    One of 264 with paint/trim code
    For 1973 2door maverick grabber.
  9. Dave B
    Cool! :thumbs2:
  10. Craig Selvey
    Out of the ALL the Grabbers they made in 1973, to only paint 642 of them silver....I throw the rare card. Cool.
  11. 67Mach1
    67Mach1 Member
    Round Rock, TX
    1973 Maverick
    That's about what I was thinking.
    I like the color. Just thinking black not white. Perhaps the white will grow on me more
    Now it's time to start doing some research. Gas tank replacement to start with.
  12. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Neat car! I've never seen a silver one. (y)
  13. Dave B
    Easy, use one from a 76 Maverick, you can buy them new at Rock Auto, and use the 73 sending unit, that's what I did, and I've never run outta gas.
  14. 67Mach1
    67Mach1 Member
    Round Rock, TX
    1973 Maverick
    From what little research I've done I read that the 65-66 mustang tank was a good swap. If the 76 tank and the 73 sender are radially available then that may be the better route to go.
    The previous owner said he was not able to turn it over with the key. But with the key in and on run he could jump it on the solenoid.
    Any suggestions?
  15. Krazy Comet
    Same as all old Fords, neutral safety sw...
