73 grabber turbo
Discussion in 'New Members Forum' started by maverick88tc, Dec 28, 2008.
  1. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Very cool setup! Welcome to the board!
  2. Clean70
    Clean70 Member
    Minnesota
    1970 2.3 Turbo Maverick
    Greetings,
    Wecome to the 2.3 club!
    Here are some pictures of my 1970 Maverick. It is a 30,000 mile car with original body and paint. Granada brakes up front, 9' with 4.56 mini-spool out back. 2 years ago I installed the 2.3 turbo, and T-5. The motor is fairly stock (rebuilt) with the exceptions of: Custom SS exhaust manifold, custom alternator bracket, gutted and rotated upper intake, aftermarket wiring harness, Ranger roller cam, adjustable cam pulley, underdrive crank pulley, custom SS air ducting, 3" SS exhaust, custom motor and trans mount and probably a few other things I am forgetting. I am running the OEM IHI turbo at about 14 psi. Best ET to date: 14.19 @ 95 mph.
    It is currently receiving Calvert Racing springs, rear narrowed to accept larger rear tires (currently 245's), 4.56 locker and 31 spline aftermarket axles (broke a OEM 28 spline last summer), adjustable rear shocks.
  3. Jamie Miles
    Alto, GA
    I've had a few
    Holy cow, the 2.3 Mav's are coming out of the wood work now! Welcome to the board guys! I too am building a 2.3 Mav. I got all the wiring figured out and got it running back in July, but have yet to get the car drivable. Right now I'm just waiting on the Pinto oil pan to get here, which is supposed to be in the mail right now.
    maverick88tc, I hope to get to see your car in person sooner or later. We usually have a big Maverick get together at Fun Ford Weekend in Commerce, GA sometime in April. If we do it again this year, it would be awesome if you could make it down with your car.
  4. rayzorsharp
    Wow! 2.3's coming out of the woodworks now! Another cool car! (y)
  5. white trash
    white trash Member
    Leland, NC
    1969 1/2 Maverick 6cyl auto field find junker
    I should have kept the nice 2.3 I built last year and stuck in a Ranger. It was just carbureted but it would scoot for what it was.
  6. maverick88tc
    maverick88tc Member
    athens tennessee
    73 maverick grabber stock 460 s475 turbo
    yeah i would love to go to commerce, i have been to the one in bristol. were are you located at in ga. i go to brainerd drag strip alot. i was wondering if anyone else had built one or not, i couldn't stand that 456 gear , that car might actually run faster with more like a 355 or 373 . that way you wouldn't be shifteing so much. i havent decided which gear i am going to go with yet.
  7. Jamie Miles
    Alto, GA
    I've had a few
    I live in Suwanee, which is about 30 miles north of downtown Atlanta, straight up I-85.
  8. maverick88tc
    maverick88tc Member
    athens tennessee
    that is about 2 and a half hours from my house
    2 hours from my work and about 1 and a half from brainard drag strip where i am going to race it
  9. CaptainComet
    Two Turbo 2.3s!!!
    Welcome to the board guys.
  10. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    very cool....
    I had an 88 tbird turbo coupe....
    I put on a turbonetics T3 hybrid turbo.....
    Ported the head over sized valves....
    Esslinger turbo Cams
    Had the head and block o ringed....
    Ran mid 13s
    pushed a little over 22 lbs boost....
    I used a mustang warlboro 255lph pump intank....
    Put that same set up in a light mav easy 12s....
    3 inch down pipe!!!
  11. radmav76
    radmav76 Member
    Toledo, Ohio
    1976 maverick soon to be 460 powered...project on hold.
    A friend of mine had a 87 2.3 turbo ranger withvery similiar engine tranny set ups. The truck weighd in @ 2600# . It ran it's fastest with a 3.27 gear. Best et was in the 13.40's. With a 50 shot of nitrous it ran 12.30's. This was also his daily driver. It would get around 20-25 mpg.
  12. maverick88tc
    maverick88tc Member
    athens tennessee
    so how much should my car wiegh with this setup i have no idea? i know the turbo parts add a little wieght to the 4 cyl. , any guesses?
    the kill list so far is an 08 s200 honda type s or something by 2 cars and a 5.0 coupe mustang 5.0 , t5 4.11 8.8 posi, with all the typical bolt on's except heads. got it by about a car.
  13. Clean70
    Clean70 Member
    Minnesota
    Mine weighs 2,940 lbs. in street trim with about 1/3 tank of gas.
    1,500 lbs. front, 1,490 lbs. on the back.
  14. maverick88tc
    maverick88tc Member
    athens tennessee
    with you in it or out of it ?
  15. Jamie Miles
    Alto, GA
    I've had a few
    The 2.3 is not a light engine. Even in N/A form, it weighs almost as much as a 302.
