73 mav. Ls1 install
Discussion in 'Technical' started by Mlovett, Dec 9, 2013.
  1. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    this is so awesome. I want to do this to my maverick as well. Has anybody done a write up on how to install and what you need for this to be done??
  2. MR T
    MR T Member
    spokane wa
    1970 maverick
  3. 71gold
  4. ProMotive
    ProMotive New Member
    Harrisburg, PA
    74 Comet GT
    Not a fan of the LS1 but a huge fan of the different. I would spend time looking at your car at a show. I personally want to build a 72 El Camino with a supercharged 4.6 cobra engine :yahoo:
  5. h2o
    h2o Mad Mav Man
    mexico city
    1973 ford maverick gt 289 v8
    I have a couple of questions if you don't mind.
    What engine mounts did you use to install it on the maverick?
    Didn't that engine has the optispark (or whatever name has the distributor it uses) and that thing causes trouble and is expensive to replace? Or that's another kind of ls engine?
    Thanks in advance.:Handshake
  6. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    You're thinking LT1 and yes those had distributor problems. The LS engines ran distributorless ignition.
  7. h2o
    h2o Mad Mav Man
    mexico city
    Oh I see! Sorry my bad!:cry:
  8. 71gold
    here is my carbed LSX distributor...:outtahere:...:drive:...:chirp:
      File size:
      117 KB
      33
  9. bLaH_hA
    bLaH_hA Member
    jacksonville, fl
    72 mav grabber(sold), 1970 maverick grabber clone
    Love the fact you left it fi I always like the way the ls intakes look. I if didn't want another maverick I would get a third gen camaro and do an ls swap
  10. Mlovett
    Mlovett Member
    Westlake la
    1973 maverick
    73 mav
    It's an RC motorsports front end and t got the motor mounts from speedway motors I think. Possibly from eBay. Been a long time since I bought them. Sorry
  11. 71gold
    I made a plate to match the stock motor mount holes and drilled it to mount 350 Chevy motor mounts to it.
      File size:
      104.5 KB
      32
  12. Mlovett
    Mlovett Member
    Westlake la
    1973 maverick
    Very good idea. There are lots of ways to do it. As long as it works and looks clean
  13. Mlovett
    Mlovett Member
    Westlake la
    1973 maverick
    73 mav
    One thing I have to tell y'all is that if your going to run a fly by wire throttle body and your going to run the steam lines to the water pump make sure you drill the hole behind the pump. If you drill the hole on top the sylonoid for the throttle body will not fit. The fitting gets in the way
  14. Mlovett
    Mlovett Member
    Westlake la
    1973 maverick
    73 mav
    Another thing I can't stress enough is buy yourself a good quality wiring harness. I started out trying to use a truck harness and delete the things I didn't néed. Then I bought a used harness , another failure. Then I decided to buy a new one. Sooooo easy. Kinda expensive but I know what I have and not worried about shorts. I bought mine from PSI. Plug and play. So simple a caveman can do it. Lol. You will be glad you bought a quality wiring harness
