74 maverick Ac box question
Discussion in 'General Maverick/Comet' started by Tfain1324, Apr 17, 2019.
  1. Tfain1324
    Tfain1324 Member
    Desoto, Tx
    1970 Maverick project, 1974 Maverick
    20190417_210012.jpg 20190417_205915.jpg I am currently in the middle of redoing the ac box in my 74 maverick and when I took everything apart this rubber grommet that fits around the evaporator core lines and seals around the hvac box crumbled to pieces and I was wondering if anyone had a suggestion on where to look for a replacement or how to go about making something that would work 20190417_210012.jpg 20190417_205915.jpg
  2. CaptainComet
    Not really a help here, just an FYI .... When I redid my A/C box, I used a gasket kit for a Mustang (71-73 I believe) but I don't recall it having that piece. I think mine might have still been OK. Most all of those gaskets and foams worked for the my box and I only had to fab up one or two.
    This would probably be hard to locate. Maybe it could be a great project for some high school kid with access to a 3D printer? Glue this one back together to use as a model?
  3. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
  4. Tfain1324
    Tfain1324 Member
    Desoto, Tx
    Thank you its at least a start I actually have a new unrelated question about the squirrel cage, I pulled the one off the old blower motor and it bent slightly taking it off well I bought a four seasons 35611 to replace it with because it was suggested for it but ive also seen it mentioned on a couple other threads, but it's slightly smaller and oriented the opposite way. So my question is should I run with the slightly warped one ive powered it up a couple times it doesn't have a noticeable vibration but I can visibly see that's it's slightly off while its spinning or run the reversed cage? 1555639588855284639184604130703.jpg
  5. CaptainComet
    I don't know that a reversed fan cage would work well.
    I just checked Rock Auto, and it is more bad news ... no fan motor or cage for factory air for a 74. I got a fan motor from them probably 8 years ago on clearance, but now they don't list anything. I would try to locate part numbers and search that way if possible. I would bet there is crossover to a Mustang or other Ford part.
  6. Krazy Comet
    A reverse angle on blade will be pulling air in vent(s) and blowing it outside, send it back. With the small size, won't be very efficient if blades were correct.
    Truing a squirrel cage is usually simple.
    To find point it's bent outward the greatest amount, spin by hand while mounted on motor (a dial indicator is a big help but not absolutely necessary).. Mark the most outward point with a sharpie or similar. Cup hands around cage, apply pressure at marked point to move cage toward center, recheck & repeat as necessary.
