75-80 Granada spindle won't fit!
Discussion in 'Technical' started by JM_73, Oct 28, 2024.
Tags:
  1. JM_73
    JM_73 Member
    San Mateo CA
    1970 Maverick, 1973 LeMans
    Hey all, I'm encountering something pretty strange, I went to put Granada spindles on my 70 maverick, however the lower ball joint is completely wrong. the new spindle bottoms out before any of the taper engages. Is this a known thing or is this unusual? And how should I correct it? I already plan to replace both upper and lower ball joints since they're all shot, but now I'm not sure what parts to order? I know they make ball joint spacer sleeves should I use those or buy factory maverick stuff from a different year? Or even Granada ball joints? Thank you and sorry for the questions.
  2. bmcdaniel
    Where did you get the steering knuckles?
  3. Krazy Comet
    Dismal Swamp
    Replace complete control arm assemblies. Replacement fits everything 170 Mav thru late 70s Granada. Ones I used had larger/longer studs, had to use washer under nuts to maintain correct height for nuts. This was 10 years ago.
  4. f4294v
    f4294v Member
    Dallas
    73 comet
    I've read the Versailles spindles had larger ball joint. Maybe those aren't granada spindles
  5. JM_73
    JM_73 Member
    San Mateo CA
  6. JM_73
    JM_73 Member
    San Mateo CA
    That's possible, this is my first Ford so I'm not used to all their quirks.
  7. JM_73
    JM_73 Member
    San Mateo CA
    That's really good to know, I'm gonna compare the ball joint tapers online if I can tonight.
  8. bmcdaniel
  9. f4294v
    f4294v Member
    Dallas
    73 comet
  10. bmcdaniel
    $71? CPP sells them for $6.
    TeeEl likes this.
  11. JM_73
    JM_73 Member
    San Mateo CA
    could you please link that? i cant find it on their site
  12. bmcdaniel
    Yeah, they don't show them on their web site, you gotta call or email them. I only know about them because a few years ago I installed one of their mini subframe kits and ran into the same problem. They offered me the tapered sleeves for $6, they might cost a little more by now. They were slow getting back to me about my problem so in the mean time I had installed ball joints with larger studs. There's charts online for Moog ball joints that give detailed dimensions, if you wanted to go that route.
    I would be contacting the place that sold you the knuckles.
  13. Powerband
    Powerband Member
    NY's \H/
  14. dyent
    dyent Member
    vancouver bc
    The sleeves that Mustang Steve sells are for each!!!
    https://www.npdlink.com/product/adapters-tie-rod/212946
    National Parts Depot at least sells them in a pair........
    If you are going to replace all the Ball Joints anyways, as Krazy Comet (Tom) mentions, you might as well just put the money towards correct lower control arms/ball joint with the proper size tapered stud. For the cost of 2 tapered sleeve adapters, you can purchase 2 new lower control arm/ball joint assemblies..........
    David
    mojo and Krazy Comet like this.
