76 instrument cluster
Discussion in 'New Members Forum' started by Pauliwog, Dec 17, 2021.
  1. Pauliwog
    Pauliwog Member
    COLORADO
    76 ford maverick with a 302
    Trying remove the instrument cluster in my 76 and it seems to be stuck. 1639788544144755572734652052503.jpg 1639788544144755572734652052503.jpg I'm pulling out on the top but will not come out. I understand the top pulls out then the speedo comes off then you lift the bottom to remove it from Clips. Any suggestions?
  2. CA189HJN
    CA189HJN Robert Couse-Baker
    Sacramento, California
    1973 Ford Maverick 4-door 302
    You must disconnect the speedometer cable clip that holds the cable to the frame under the car. It prys out with a screwdriver. Then, push on the cable and the cluster should come loose at the top. After you maneuver the cluster enough to get your hand behind the cluster, you'll disconnect the speedometer cable from the speedometer head, and remove the alternator indicator light and main instrument electrical plug.
  3. dyent
    dyent Member
    vancouver bc
    Did you remove the 2 screws at the top, just above the gauges?
    David
  4. Constable
    Constable You have the right to remain silent....or not!
    Portersville, PA
    1975 Maverick 4 door, 1994 Mustang GT convertible
    Yes, remove the screws.
  5. CA189HJN
    Yes, that's absolutely essential. I had assumed you had already done so and couldn't figure out why it would not move with the screws out. The first time I took out the gauge cluster, it took two hours. Once you get the hang of it, it takes five minutes. Everything on these cars is like that for me.
    Russell likes this.
  6. 71gold
    try not to over tighten the screws when reinstalling the cluster, old plastic can't take it.
    CA189HJN and mojo like this.
  7. TeeEl
    TeeEl Senior Member
    Colorado
    Don't forget the screw on the side, inside the ash tray...
  8. dyent
    dyent Member
    vancouver bc
    I do not recall any side screw, other than the 2 at the top on all the clusters I have removed from all of my Mav/Comets?
    David
  9. Pauliwog
    Pauliwog Member
    COLORADO
    Thank you for the info and I did get the cluster out. I cleaned everything up and replaced all the bulbs because I had very dim the lights and put it back in and still have very dim. Lights. Any thoughts on that? I think it probably a ground issue but not sure where to look I was thinking maybe the light switch?
  10. Pauliwog
    Pauliwog Member
    COLORADO
    Yes I was able to get it out and changed all the bulbs but was unable to make the lights brighter. My Dash is still not very bright so I'm going to try to change the light switch. Thanks for the help
  11. CA189HJN
    I did that for the same reason and the instrument lights got slightly brighter. Still aren't very bright, but good enough.
  12. Krazy Comet
    There are only three bulbs used for cluster illumination, not nearly enough, all are dim.
  13. Craig Selvey
    Yes....all are dim. It is a 1976.....not a 2006.
  14. mojo
    Paint inside of cluster white or something close in contrast. It will make a difference in brightness.
    Some have replaced bulbs w/ LED's claim they increase light output. I painted mind made quite a difference.
    CA189HJN likes this.
  15. TeeEl
    TeeEl Senior Member
    Colorado
    LEDs will absolutely brighten your instrument cluster. I put green LEDs in mine...
