78 cougar v8 dropped in but unsure if the engine is connected to trans??
Discussion in 'Technical' started by Fenris Ulf, Aug 22, 2005.
  1. 71gold
    give jamie an "at-a -boy"!!!(y)
    that was way big of him to pull his motor and tranny to show him what we are talking about. terry, will have to take back half of the bad stuff he has said about him...:yup: ...frank...:bouncy:
  2. Jamie Miles
    Alto, GA
    I've had a few
    Frank, you's to funny man. :rofl2:
    Pics are from when I had the engine/trans out back in June. Wish I could go back to the day I took those pics, theres a few things I would do diffrently now. :)
  3. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    My exact thoughts.
  4. Fenris Ulf
    Fenris Ulf New Member
    VA
    1976 comet
    That all is extremely helpful guys, :) After looking at everything I beleive that yes the torque converter is bolted on but from all this and talking to a few people I know I am lead to theink that the filter is not letting the trans fluid into the trans, when I pulled the dip stick the fluid was halfway up the stick when the engine was cold, when its cold it should only be at the very end right? so when I get some time I will drop the pan and change the filter and see how that works for me, again thanks all for the info :) !
  5. Jamie Miles
    Alto, GA
    I've had a few
    When you check the fluid, the car should be fully heated up and idleing in park.
  6. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    The converter may not be in the transmission completely.
    Had this happen. it wouldn't engage the pump, therefor no motion.
    It ended up costing me a broken flywheel also because the bellhousing bolts had back out... causing the converter to come out of the pump...
    blah blah blah
    Wasn't a very fun fix at all.
    Hope yours is something simpler
  7. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    If I paid a mechanic to do the work ... I wouldn't even get my hands dirty troubleshooting ... it would be right back with the mechanic ....
  8. stockhatch
    stockhatch Re Member
    Boiling Spring Lakes NC
    '72 Grabber
    What he said.
  9. texas_maverick
    texas_maverick Member
    Telephone, TX 75488
    71 ford maverick
    if you are going to change the filter yourself then watch out there is a little spring under the filter ear. if you don't put it in with the lil plastic piece going into the tranny then you will burn it up. i did it and had to pay 375 for a rebuild.
