8 Inch Rear End - How Strong?
Discussion in 'Drag Racing' started by cometguy, Nov 10, 2009.
  1. yellow75
    Tillamook Oregon
    Splines wore out, this wasnt one of the $18.00 cheapies either. I was running a top loader and launching at 5,500 rpm on slicks though, might have has a little to do with it :) Also twisted the axle housing one time right at the spring perch. With an auto it would not be nearly as brutal.
    Went to a 9 inch and never had a problem after that even with a mini spool
  2. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
  3. yellow75
    Tillamook Oregon
    Yes it would be Dave Flett
  4. Rick
    Rick G8I operations
    Ocala, Florida
    Here's was mine after the caps failed
  5. Blown 5.0
    MS.
    1974 Maverick
    Looks just like mine except mine broke thru the adjuster screw holder bolt hole. (wow say that three times fast) Looked almost like they were cut in to with a band saw.
  6. cometguy
    cometguy Member
    Schomberg, Ontario, Canada
    72 Comet GT 302/AOD, 1972 Mustang NHRA Stock Eliminator 351C
  7. Racerb
    Racerb New Member
    Delano CA
    72 Grabber
    Anyone make after market axles for the 8" running a mild 302/348 with C4 mid to high 12.0's
  8. maverick maniac
    maverick maniac Banned
    owensboro ky
    yep strange and mossier both make 28 spline axles
  9. td8
    td8 New Member
    Both 8in an 9in axles are the same. The 8in pinion shaft is smaller than the 9in. Moser engineering makes axles up to 40 spline but the problem with the 8in is a spool. You can get a 31 spline mini spool but I have never seen a full spool for a 8in.
  10. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    In some cases it's the weak main cap bolts that allow the caps to walk and break. In other cases I have seen the pinion push them out due to a weak pinion carrier. My father ran them behind big block 427/429 in a 4 speed fairlane with good luck. To my knowledge he only grenaded one. They are stronger than some give credit if you address the aforementioned issues......It's in the air right now I have a Currie ALumin8 carrier but I may go with a quick change 9 inch in my car........
  11. jayss10
    jayss10 This is Minerva
    INDIANA
    1971 MAVERICK,73 GRABER CLONE
    ive had a 8 inch in mine i 1.55 60 ft ,havent had any problems yet it has a mini spool stock axels ,im going to mosier this winter ,but will probably leave the mini spool
  12. maverick88tc
    maverick88tc Member
    athens tennessee
    73 maverick grabber stock 460 s475 turbo
    i have never ran the 1/4 but my turbo car ran a 8.00 in the 1/8th with a 6500 rpm launch and i even sprayed it a couple times but it just spun i have a mini spool (15$) and stock axles with a diy setup without the proper tools just did it by feel and by ear . but that is like a super low 12 in a turbo car with a 5 speed
  13. murphy88
    murphy88 Member
    waterloo on
    73 maverick 76comet
    I have me a 8" detroit locker with 410 gears..I will find out this summer what it will take ..lol
  14. 71gold
    ...and what times are you running with this setup?
  15. Ol Maverick Man
    Ol Maverick Man Member
    Wallingford, Ct.
    1973 Maverick Grabber Clone
    I had a 8 inch rear in a 1933 Plymouth coupe with a 440 and auto transmission. I made sure the slack was out of the driveline and ran a 1.70 60ft. time. Never had a problem
