8 inch rear swap question..
Discussion in 'General Maverick/Comet' started by Matterick, Jan 4, 2015.
  1. Matterick
    Matterick Matt Somerville
    Lake Stevens WA
    71 mav with a 170..will the 8 inch require a driveline from a 5 lug car?
  2. yellow75
    Tillamook Oregon
    Have you looked to see if it is an 8" ? If it is original it will be the 7.25" rearend. Either way it would just be a matter of finding the correct u joint but I believe any driveline from a 2 door car will work
  3. Matterick
    Lake Stevens WA
    Haven't looked yet, but I did notice the driveline is a skinny little thing. Sounds like I should be ok though if it's just a matter of the right u joint! Thanks!
  4. 71Mavrk
    71Mavrk Member
    Nevada
    I believe it was the first year for production that had the smaller rear end. My '71 had 8". I swapped in one from a '74 with zero problems and used the original drive shaft.
    Micah
  5. Craig Selvey
    As far as I have ever seen.....ALL 1971's had the 8" rear axle.
  6. Matterick
    Lake Stevens WA
    Ah now I see where I brought in some confusion....I'm switching to the 5 lug 8 inch! My bad guys!
  7. mav1970
    Are you referring to the drive shaft?
  8. silver70
    silver70 Eric
    Phoenix, AZ
    '70 Maverick
    I pulled my original 1970 200/3-on-the-tree/7.5" and swapped in a 302/C4/ 8" from a '74 and my skinny stock driveshaft from the '70 worked just fine. Length, splines, U-joints, everything. If that helps at all. :huh:
    Eric
  9. rthomas771
    Early Mavericks came with a 7.25" ring gear.
  10. yellow75
    Tillamook Oregon
    My bad also I was thinking since the car had a 170 then most likely it would have the 7.25 rearend, sorry for misinformation as the 71 should have the 8" with 4 lug bolt pattern
  11. silver70
    silver70 Eric
    Phoenix, AZ
    '70 Maverick
    Oops. I guess I had the 7.25" then, too.
  12. Lee Richart
    Lee Richart Member
    Redford, MI
    1973 Maverick LDO 421W
    If indeed it is a 1971, it should have an 8". All you have to change to get five lug wheels are the axles and brake drums.
    Lee "THE MAV" Richart
  13. rthomas771
    5-lug 8" axles don't fit a 4-lug 8" housing...the axle bearings have a different O.D. and different I.D.
    To make the swap the ends of the axle tubes will need to be swapped.
    Mel Moeller likes this.
  14. Craig Selvey
    I have heard that one can custom order a bearing to do this swap as well....but doesn't really seem worth all the extra work. :D
