8 inch rear to a 9 inch
Discussion in 'General Maverick/Comet' started by ZaksComet, Jan 10, 2012.
  1. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Here is the thread for the housings
    http://mmb.maverick.to/showthread.php?t=59002
  2. ZaksComet
    ZaksComet Member
    Cleveland, Ohio
    1972 Mercury Comet
    My goal is to turn my stock rear end of my 72 Comet into a positive traction. My buddy said it would be cheaper switch it to a 9 inch rear positive traction. My just trying to find the best and cheapest way do make it a posi overall.
  3. ZaksComet
    ZaksComet Member
    Cleveland, Ohio
    1972 Mercury Comet
    I put 3:80's and a new Traction Lock in my 8" for about $550.00....Lighter than the 9" too
    Did you have the stock 8 inch rear?
  4. mercgt73
  5. Streamliner
    Streamliner Member
    Yep, it was in the car when i got it
  6. ZaksComet
    ZaksComet Member
    Cleveland, Ohio
    1972 Mercury Comet
    Ahh ok, how does it drive with that now? i may just do that instead
  7. yellow75
    Tillamook Oregon
    Do you get a poster with the girl on it also when you buy the kit :p
  8. ZaksComet
    ZaksComet Member
    Cleveland, Ohio
    1972 Mercury Comet
    fingers crossed! :clap:
  9. 71gold
    don't know if these two words go in the same sentence...
  10. Streamliner
    Streamliner Member
    Drives great but if it's for an everyday driver without an overdrive, the 3:80's may be a little steep....Might be better with something closer to 3:25-3:50
  11. CaptainComet
    IIRC, there can be a weight penalty of about 40 lbs, using a 9 inch vs an 8 inch. An 8 inch will stand up to a lot under a light car like ours if built right.
  12. ZaksComet
    ZaksComet Member
    Cleveland, Ohio
    1972 Mercury Comet
    i think i may take the plunge and just do that to turn it into a posi then
  13. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    You should look into this
    http://www.richmondgear.com/powertrax/lockright.html
    or this
    http://www.richmondgear.com/powertrax/noslip.html
    you can do either one yourself with limited knowledge. I had NEVER seen the inside of a rearend before installing mine and I just followed the instructions that came with it and a couple added instructions from the internet and mine has been in for 2 years now and I have not been easy on it to say the least.
    BTW either of these install into a stock 8 inch rear.
  14. ZaksComet
    ZaksComet Member
    Cleveland, Ohio
    1972 Mercury Comet
    I like that, how much does that run you?
