...8" rear disc. installed...
Discussion in 'Parts Interchange' started by 71gold, Dec 10, 2007.
  1. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    thanks for that info 71gold.
  2. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    Any other pics of this swap?
  3. 71gold
    ...news flash...
    i took a set of the ...big hole brackets and...drilled the (small bearing) 8" clocked holes in them and they will work also... :yup:
    i did these for a guy with a street rod truck with a Ford 8" rear.
    ...Frank
  4. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    I guess I can glean the process from the pics you posted. I was just looking for assembly pics. Kinda one by one as the components went on.
    Sorry for sounding stupid. I just want to da it as well and do it right.
  5. 71gold
    nothing...stupid...here...
    i will be glad to help in anyway i can. if another pic. will help i will take it and post it...i want this to be as simple for everyone as it was for me...
    axle housing seal-1st...shim-2nd...bracket-3rd...axle-4th...axle bolts-5th...rotor-6th...cali.-7th..brake line-8th...wheel-9th...pics...-10th:thumbs2:
    ...Frank
  6. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    Thanks Frank
    I just didn't wanna burden you.
    I appreciate you posting this.
    Ed
  7. 71gold
    no one asked, but...
    the reason for the shim...
    the ...shim...spaces the axle bearing out flush with the cali. bracket..
    this way there is no ...endplay...in the axle.
    i was thinking about ...making for sale...these shims.
    mine were ...200/1000th"...if we check and they fall in 100/1000th" increments maybe we can find a ready made source for them...
    i will research this more...
    ...:yup:...
  8. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Thanks Frank. This is great info. Just want to confirm/clarify two things:
    1) the shim keeps there from being a gap between the housing and the axle bearing, due to the thickness of the bracket pulling the axle farther out. Right?
    2) the seal.. maybe I've just never paid attention when I've pulled and replaced axles... what does it look like? I guess it stays in the end of the tube when you pull the axle?
    And if you don't mind, can I see a pic (from the end like the ones showing the drum and the installed rotor and caliper) of the axle installed without the rotor?
  9. blugene
    :scratchchin:Hmmm. :hmmm:Now I need to look at mine...
  10. 71gold
    1) the...bracket...doesn't pull the ...axle...when the ...axle plate... is bolted on. it leaves a void between it and the bearing. that lets the bearing/axle slide back and forth in the housing/bracket.
    i am looking at a ...split shim...to put over the axle between the bearing and the plate. that would be the best place for the shim but to put it there would mean pressing the bearing off and back on.
    2) the ...seal...is in the end of the ...housing...(see pic.)
    i will have to pull the rotor and get that pic.of the axle end tomorrow.
    ...Frank
  11. 71gold
    i think these are the pics. you wanted...
  12. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Good Job Frank.
    You should write this up and submit it to Dennis for a Shorthorns article.
    mavaholic@aol.com
    Thanks for sharing.
    Seth
  13. Grabber5.0
    Kansas City, MO
    71 Grabber
    Thank you very much Frank. :yup:
  14. jayman
    jayman Member
    San Diego, Ca
    69.5 Maverick/72 Grabber
    I just have one question. '96 Lincoln what? TownCar? Mark VIII? I would hate to buy all the parts and find out that I go the wrong car. :cry:
    Thanks loads. This setup looks like a great bang for the buck!
  15. stangclone
    stangclone Member
    ofallon,il
    1972 maverick,1965 mustang
