8" Rear End Gears
Discussion in 'Technical' started by Erick-Mav, Dec 14, 2004.
  1. tim keck
    sharps chapel,Tn
    yes it's direct replacement for your stock rear.With 3.55's and 26" tall tires my mav turned 3000 at 60 w/3500 stall,2800 w/stock converter,2800 w/3spd manual.(y)
  2. Zechs_wind
    Zechs_wind Old School Ford Rules =]
    757, 434, Virginia
    1974 Ford Maverick, free 1970 Maverick that needs everything.
    I was thinking, is there any companies that make performance 8" rears?
  3. Mavaholic
    Currie, Randy's Ring & Pinion are a couple. I'm sure there are more. I would stay away from Perogie. 2 of my friends have bought stuff from him that just wasent right.
  4. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Just like the Maverick, Pintos and Bobcats could have either the 7.5 or 8 inch rear. Engine size or number of cylinders does not matter.
    If the car has an 8" rear, it breaks down something like this:
    4 cyl auto tranny: 3.40 with optional 3.55
    4 cyl manual tranny: 3.40
    A/C cars are 3.55 standard if memory serves.
    V6 cars are 3.40 and the trac-lok was optional.
    The rears are small bearing 4 lugs, so the only part that is interchangeable with our 8" rears is the chunk. Identical.
    You wouldn't want to use anything else anyway.
    I am surprised this stuff isn't common knowledge here.
    Now that the cat is out of the bag, I'll never get a cheap Pinto chunk again...
    Dave
    Edit:
    Late 60s-early 70s: Fairlane, Torino, Ranchero, and maybe others...
    The 3.28 gear is common in 8" rears for these cars. I have no idea about the availability of trac-lok.
    Just in case someone wanted a very mild increase over the 2.79-3.00 gear set.
  5. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Yeah, I knew about Mustang-IIs, but I never knew about Bobcats. I wonder if any of them actually had Trac-Lock. Will have to keep my eyes open for them as well now. Buddy of mine wants some better gears than the 2.79s he's currently running...
  6. Jap901
    Jap901 Member
    Scotts Hill Tn
    71 mav 2 door
    http://mmb.maverick.to/showthread.php?t=10252
