9.40 at 140 mph
Discussion in 'Drag Racing' started by riporter, Apr 10, 2006.
  1. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I believe the rules state that a chute is required on 9.99 and faster. Your required to deploy a chute at 150mph and up.
  2. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    This was an NHRA track (in fact, owned by NHRA) and they let Rick run everyday without a chute. There were others running faster that 9.9 without chutes. Every car running 150 mph and faster had chutes. Not all deployed them. The guys runing 7.40 and faster deplyed, but their speeds were over 170 mph. Atlanta Dragway has a fairly long shut down area. I thought the rule was for mph not ET.
  3. riporter
    riporter Member
    Charleston S.C.
    Terry is correct. It's any car over 150...ET doesn't matter...as anal as the track officials were there if I had run over 150 they would have told me...no chute...no pass, whether I needed it or not.
  4. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    Another economical reason for you to stick with 1/8 dragging, huh, Rick? :yup:
  5. riporter
    riporter Member
    Charleston S.C.
    You mean there is something ECONOMICAL about all this:huh: :tsk: :49: :16suspect :biglaugh: :biglaugh: :biglaugh:
  6. bossmav
    bossmav Drag racing nut
    Harrisonburg, Va
    74 Grabber now Pearl white
    The second 1/8 mile is where I win most of my races but then again my car is setup for 1/4 mile racing. 4.11 gear ratio.
    1/8 mile is Ok but I'm OLD school... Real drag racer do it a 1/4 at a time!
    I'm sure this post will start something!
    SWEET run Rick you must be proud!;)
    Bossmav
  7. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    Would "Another somewhat less expensive reason for you to stick with 1/8 dragging, huh, Rick?" have been better?:confused:
  8. igo1090
    igo1090 Member
    catonsville, md
    sorry. nhra div 1 stuck in a rule a few yrs ago that anyone exceeding 135 mph needed all the under 10.00 equipment including the chute. just a div rule.
  9. stmanser
    Davenport, Iowa
    do you change gears or setup when you go from 1/8 to 1/4 tracks? seems like it would be a pain to remove the center section to go to different length tracks
  10. riporter
    riporter Member
    Charleston S.C.
    It won't start anything with me:evilsmile I think it all depends on what you cut your teeth on as to what your preference is...I like em both.....BUT, that second 1/8th is a "Sunday Drive" compared to the first 1/8th:p .....:D
    here we go:tiphat:
  11. riporter
    riporter Member
    Charleston S.C.
    Simon read ALL of the first posts...it explains what I did to run the 1/4 without changing the gears out.
    A 4.56 gear would have been optimal I think, but I would've just been happy with the tranny workin right.
  12. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Nice run, "Ripper". (y)
    I read the posts, I don't think anyone asked what size tires you run (I'm guessing 10.5W x 29.5")
  13. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Friggin sweet!!!!!!!
  14. riporter
    riporter Member
    Charleston S.C.
    Big Meats Rick....32x15's..a big burnout like in the video is really a waste of good rubber.
    It turns out my tranny is okay for the most part but the converter is mush, most of the internals were laying in the bottom of the tranny pan, that explains why my 60's went from a 1.22 to a 1.33 over the last 20 passes or so:90: the converter came with the car when I got it and did fine when it was a 408 but just couldn't handle the 427....
    hmmmmm...wonder what it's gonna do with a fresh converter in it:49:
  15. CornedBeef4.6L
    no longer here
    Blasephemy:mad: Long Live the Burnout:yup:
