9" rear end troubles
Discussion in 'Parts Interchange' started by eds73mav302, Aug 18, 2009.
  1. eds73mav302
    eds73mav302 Member
    pomona ca, 91767
    maverick
    thanks for the picture guys, helps alot! ok so what are my options though?
  2. eds73mav302
    eds73mav302 Member
    pomona ca, 91767
    maverick
  3. maverickmadness
    maverickmadness Member
    ala
    1973 maverick grabber, 1972 maverick grabber,1974 maverick grabber,
    u joints
    thats all you should need is a different u joint. they come in many sizes. measure the cups and widths. give them to your parts guy or uhmm gal. napa will have them. i cant remeber the part number so im no help there. but just measure cup diameter for both drive shaft and 9 inch yolk, then the width of both then you should be good to go
    :idea:
  4. 71gold
    have your parts person pull a u-joint for a 9" 57 ford and one for a '75 maverick 8". measure the 9" on one side and the 8" on one side. tell them you need one with thoes measurments...then adjust from there if needed...:yup:
    ...:drive:...
  5. CaptainComet
    Everyone has hinted at it, but what needs a little clarification here is that you need to ask for a special u-joint that is made for a non-stock application. These are made for this kind of swap. A stock u-joint usually is the same size in both dimensions. What you need has both sizes built into it.
