9"
Discussion in 'Technical' started by seth, Apr 7, 2008.
  1. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    what cars can i find a 9" axel in for a axil swap in my 69?:)
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Closest would be 57-59 Full size or 75-80 Granada.
    They are bolt in, but are slightly wider.
    Other rears that are direct bolt in would be:
    67-70 Stang/Cougar. They are significantly wider though.
    Requiring more backspace on the rims to get them back under the car.
    71-73 Stangs will bolt in too, but they require ridiculous backspace due to great width. They would take a late model Stang rim with no problem or spacers.
    The late Stangs have something close to 7" backspace, and that is what you need to tuck the tires with one of those 71-73 monsters.
    65-66 HiPo Stang (K-code... or Shelby) 9" rears will work too.
    However they are valuable and you probably won't find one laying around.
    That said, Ford and Shelby made the 9" rears for those 2 years by grafting them into the stock 8" rears. They took the center out of the 8" rear housing and replaced it with a 9" housing center. The 8" used the same 28 spline axles and small bearing tubes, so it all hybrid together nicely.
    If you have a stock 5 lug 8" rear, you can get a 9" housing from any cheap/free donor and graft it into your 8" for not much dough. Costs around 200 bux in my town.
    Then you have a ready to bolt in 28 spline 9" rear, no narrowing or resplining.
    No getting new rims with more backspacing either.
    Good luck
    Dave
  3. baddad457
    Last but not least is the 75-80 Lincoln Versailles. 1" wider than the 65-66 Stang rear. All the Versailles had the 9", it was optional in the same year's Monarch and Granada.
  4. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    Can a 90s axel from ford ranger work i think its around the same width
  5. newtoford
    newtoford Member
    New Castle Delaware
    i think rangers would have a 8.8 or 7.5
  6. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    i know some have 8.8s but i dont know if it can be used
  7. baddad457
    It's near the same width, but the pinion is offset 4" to the passenger side. You can use an Explorer 8.8 and narrow one side and then relocate the spring perches. I know some have done this in the Classic Stangs, but don't recall what the finished dimensions were. The Explorer rears are prefered over the Ranger rears due to they have 31 spline axles (ranger's are 28's) and many have posi units and some have disc brakes. Ratios run from 3.08 to 4.11
  8. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    8.8s suck! well sort of...i dont like the c clip rears
    i have a 57 ford fairlane 500 9inch in my car and yes bolted right in with out an issue:cool:
  9. baddad457
    The C-clips aren't an issue if you narrow both sides, you can replace the axle housing ends with 9" style and eliminate the C-clips. (y) This is what I did with the Exploder rear in my Ranger.
  10. eddie1975
    Martinsburg, WV
    sold
    yeah tis is true good point(y)
