$98 paint job
Discussion in 'Cosmetic' started by markso125, Sep 6, 2007.
  1. bmcdaniel
    They use the Canadian version of Rustoleum paint. Not many colors to choose from. If you prep well and use some elbow grease buffing and polishing it would probably come out not much worse than the factory enamal paint jobs from the 60s. And if you don't like it when it's done you can sand it off and not be out much money.
  2. bmcdaniel
    That's no excuse. School is a waste. Make her work until she's at 8 1/2 months... :cool:
  3. rayzorsharp
    Time's a wasting...get that roller out!!! :)
  4. newtoford
    newtoford Member
    New Castle Delaware
    flat black and its a wrap :)
  5. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    Mark, I'm in the same boat you are. I've got no money and about the same amount of time.
    I'll tell you what the real trick is to getting a good deep shine out of just about any base coat. You put about 5-7 layers of high gloss clear on top of your base coat. You can buy the rustoleum in clear, and I'm sure it's not as good as a dupont clear, but there's something about beggers and choosers.
    Anywho, after you wet sand, rub, and buff that clear, it'll look 10 times better than if you just try to finish off the base coat.
    The US version of Tremclad, which is Rustoleum, isn't quite as nice because our VOC emissions laws won't allow the canadian version to be sold here.
    One thing of note is that it takes the Rustoleum FOREVER + 1 DAY to properly cure. It's like you paint it in the fall, so it can cure over winter and then you can drive it in the spring. At least, that's what I was able to glean from some of these articles.
  6. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    School?
    Said the 65 year old laborer:rofl2:
  7. markso125
    markso125 Member
    Lewiston Ut
    I have recieved some interesting responses, and from what I have seen this is not looked highly upon either due to it being different or what, I was primarily curious if anyone had tried it or knew someone who has that could give me an opinion on a finished product. I am really surprised by some of the resistance by some of the quotes this has recieved, from what I have seen new and different ways of doing things are not only accepted on these forums but they are highly applauded. I am sorry I have caused such a commotion and I hope that I have not caused abrasion within the group
  8. tweet66
    tweet66 where am I?
    Pennsauken, NJ
    I've considered it on my 76 Mav after reading about it on a Mopar:16suspect website. I went so far as to buy 4 qts. of light blue Brightside topside boat paint (single stage polyurethane paint), the rollers, and all teh other crap involved but just haven't gotten around to it:( Now I'm trying to sell the car so it'll probably never happen, but I'll find something to use the paint on(y)
  9. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Newtoford, your car looks pretty sweet for rattle. I think it all depends on what look you going for. I know you won a rat rod trophy so obviously if you going for the ratrod look then be as much of a minimalist as you can. If you wanna be inbetween then you can do some body work, get a cheapo Maaco or 1day paint or earl sheib and then buff it til it looks great. And of course if u want an amazign look, either gotta do it yourself or spend lots of $$$ and have it done.
    For me the problem is the air compressor. It's a 5-6 cfm air compressor, I can't do much painting with it so going roller is probably a pretty decent option.
  10. cenc1984
    cenc1984 killa 72
    Middleburge FL.
    1972 Maverick Grabber
    ok great, so that takes care of the paint but.....what about some inexpensive pirmer and etching primer? I like what I see and am really thinkin about doing it, so let me know guys and gals.
    Thanks
    Alex
  11. newtoford
    newtoford Member
    New Castle Delaware
    ive done the paint roller+rustoleum paint job on a big 4dr delta i had. i didnt thin it or anything, just used it right out of the can and it was dried on the car in about 2 hours. i didnt do any prep at all, i painted right over the dirt on the lower rear 1/4's. ive sinced stoped driving the car since i pulled the engine for something else but almost 3 years later the paint still looks like the day i put it on, even all the dirt is still held in place under the paint. its been sitting out side BTW, rain, snow, wind, sun. its held up fine.
    now the .99 cent a can walmart flat black rattle job on my mav tends to be faded out after it gets wet a few times.
    alot of model cars I build are a combination of .99 cent rattle paint and .99 cent clear coat and they come out NICE. i dont know if i'd be able to recreate that on a large scale though. blending together the lines of paint is hard to do, on a model its not even an issue.
    i like the looks of a $5000 paint job just as much as the next guy but i'd rather have the rat rod look then the cheapo macco job. to the untrained eye shiney paint is shiney paint. believe it or not i really am a perfectionist when it comes to body work. i could run it through macco as is today and come out just as nice as anything else they do but the steel and panel fit on my car is going to be "perfect" before i ever invest in something professional.i'd rather be flat black and straight then shiney with bondo and rust bubbles poking through all over the place. and believe it or not just about every oter car at the local cruises falls into that catagory
  12. red comet gt
    red comet gt New Member
    Dallas, Ga
    1972 comet gt
    All of this is fine if you have a $ 50.00 car. I've been painting cars for 30 years.
    All you're going to do is cost you alot more getting that mess off, when
    you get ready for a nice paint job.
  13. rayzorsharp
    (y)
  14. markso125
    markso125 Member
    Lewiston Ut
    so why not
    Why not try it when I can afford a $5,000 paint job would I not send the whole shell out to be soda blasted anyways?:16suspect
    Hey for those of you that are interested I found this website
    http://rollyourcar.com/default.aspx
    gives a little easier to find info and has some good closeup pics of final results
