9inch pumpkin
Discussion in 'General Maverick/Comet' started by Lzoesch, Aug 15, 2012.
  1. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    Sent should be there in a few minutes
  2. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    Broken pics lol
  3. mav1970
    OK, I thought I coud load them into my Gallery, post them for you and then delete them----I guess deleting them wasn't the right answer LOL!
    I'll get them back :cry:
  4. John Holden
    John Holden Member
    NJ
    I can't see the pics.
  5. mav1970
    Pictures:
    [​IMG] [​IMG] [​IMG] [​IMG]
  6. mav1970
  7. John Holden
    John Holden Member
    NJ
    Can't really tell much from those angles. Do you have a picture of the other side of the diff where the ring gear bolts are? At least we could tell you if it's a traction lock or open rear. Also someone may be able to decipher something if there are numbers on the carrier bearing caps.
  8. rthomas771
    Looks like an 8"
  9. mav1970
    I was just going to say that too. I don't see where the front pinion housing is shrouding those 2 bottom bolt holes - just looks smaller than a 9
  10. mav1970
    My 9 inch center section as a reference - bottom 2 bolt holes hidden by pinion housing
  11. John Holden
    John Holden Member
    NJ
    Ok I just saw the last three pics. It does look kinda small compared to the models hand. Ha ha. would be good to see the ring gear bolts. Can you fit a socket with am extension onto all of the nuts that hold the case into the rear housing? Especially check the bottom ones.
  12. John Holden
    John Holden Member
    NJ
    The ribs look like 9" though.
  13. mav1970
    Anyone yet able to determine if this is an 8 inch center section or not?
  14. Dave B
