A 77' Maverick with all drum brakes?
Discussion in 'New Members Forum' started by team trav, May 27, 2014.
  1. Acornridgeman
    Wisconsin
    That info helps. As I said in post #2 - all "77 were disc.
    So I guess that car either had front end damage and was patched up from a donor drum car, or somebody took the disc parts and it was repaired with drum parts - much the same way Craig said happened with the parts he sold a kid fixing up a car.
  2. team trav
    team trav Member
    Oakland, CA
    77 ford maverick 6cy
    thanks!
    was thinking the same...a bad swap...conversion kit is on the horizon...
  3. Acornridgeman
    Wisconsin
    BTW .... here is how your VIN decodes
    7K91L101755
    7 = 1977
    K = Kansas Assembly Plant
    91 = 2 door Maverick
    L = 250 CID / 6
    Last numbers are the unit ID
    If you want - post a picture of the complete door data sticker and we can tell you more info.
    (y)
  4. Paul Masson
    1971 Grabber
    :Welcome: from Atlantic Canada!
    I never miss an opportunity to add a VIN...http://mmb.maverick.to/showthread.php?p=1014994#post1014994
  5. Krazy Comet
    I may well be totally wrong but I'm seeing the most likely possibility as being clipped early in life, with earlier front half used and VIN swapped... Do the rivets in dash that hold VIN plate appear orig???
    Clipping was very common on unibody vehicles, had a guy I knew do a '69 Ranchero for me, used a SCJ Cobra Fairlane for front half... That BTW had drum brakes, I swapped the discs from Ranchero clip to it... Actually the clip on it was a SW(which was wrong, should have been from 2dr HT), it had already been clipped once and that clip had the RF corner replaced... AND it didn't end pretty, I sold it to a friend and the guy he sold it to totaled the front end again...
