...A/Cs turn...
Discussion in 'Technical' started by 71gold, Apr 18, 2012.
  1. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
  2. 71gold
    :cool:...thanks...
    it looks like my...new expansion valve...is bad. I don't know what a bad one would do, but the Guy at the A/C shop said mine may be...stuck open...stuck closed...stuck in between...:rofl2:
    with the gauges hooked up and I start the car...the low side goes to 32...as the car runs for 2-3 mins. it drops to 16...:yup:
  3. Dave B
    Wow, what alot of work...oh wait..that's what I dealt with all week.....
  4. 71gold
    Effie and I got the valve swapped...thanks Sweetie...:bouncy:
    pulled a vac. on the system and if it holds over night I will charge it again tomorrow...5 times in 3 weeks...:cool:
  5. 71gold
    ...well that didn't work...still 16 on low side...vent temp 65 degrees...
    will get back into it tomorrow...
    ...bought a case of 12 oz cans of 134A this time...:cool:
  6. Dave B
    Are you sure the refrigerant charge is correct?
  7. 71gold
    I have...16 at 12 ozs. system calls for...24 ozs.
    I have put up to 36 ozs. and the low stays the same. the high side goes out the top and bumps the high off limit ...:yup:
    Effie thinks I need professional help...:hmmm: what does that have to do with my A/C system...:huh:
  8. 71gold
    something different today...
    car ran with A/C on max for 5 mins...low at 12
    the compressor loaded up, the low went to 32 for about 1 min. then compressor cycled off/on and it went back to 12.
    it ran for about 3-4 mins then did it again except when it cycled off it didn't come back on for 1 min...:huh:
    ...I thought compressor didn't cycle in max air position...
    high side up/down with the trinary switch cutting fan on/off...(186-254)
  9. John Holden
    John Holden Member
    NJ
    Subscribing to this because I'm "eventually" going to be doing the same thing.
  10. 71gold
    this may not be a good thread to subscribe to...my stuff seems to act a little different than others...:bouncy:
  11. Jsarnold
    '72 Sprint
    Did you get all the oil out of the system somehow and put the correct amount back in?
    Does your expansion valve have a heat/cold sensing bulb that you can get at? Can you put some warmth on it and see if that causes it to open and let more refrigerant into the evaporator?
  12. blugene
    What kind of compressor is it again? I seen some with shut off valves..
  13. 71gold
    Sanden 508
  14. injectedmav
    injectedmav Member
    Georgia
    Any resolution, Frank?
  15. 71gold
    yes...I took it to an A/C shop...at Effies request...and he fixed it...$40...:cool:
