a few pics of my 71 maverick
Discussion in 'General Maverick/Comet' started by j miller, Nov 6, 2006.
  1. Rando76
    Rando76 Member
    Claremore, OK
    Proof that 4-doors can look good. I love it!
  2. j miller
    Polson, Mt
    i have tried a punch and it didn't work. that pin is a spring type that (i'm told) takes a special tool to release it and push it out. if this is not correct please tell me. i do want to do away with it and grind the nub down.
    b.t.w.-- good eyes
  3. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    I have a 71 2-door Grabber and I was just able to take a punch and drive out the pin. There was no spring or anything like that. It was simple so I dunno why that didn't work for you. :huh:
  4. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Mine popped right out with a punch .....
  5. j miller
    Polson, Mt
    i will try again. maybe it is just being stubborn. thanks
  6. Craig Selvey
    Try a punch or 10 penny nail.
  7. Stefan
    Montreal, QC
    Sharp car Jason!
  8. j miller
    Polson, Mt
    o k guys i have tried punches and a 10 penny nail. that pin is not moving. this one is a split pin that look like it gets tighter then further it is driven into the hole. it is not a solid pin. can this be drilled out? the only thing the nail did was bend and cause me to invent a few words.
  9. Craig Selvey
    Does it look like it will come out of the bottom? Maybe the roll pin is not lined up with the hole in the bottom of the shifter nub? It should just pop right out.....no problem.
  10. hotrodbob
    hotrodbob Member
    Central Coast, So.Cal
    Sold my 1971 Grabber
    GREAT MORE DOOR Maverick! That does look kewl!
    I just changed my shift handle. Hit it with some WD40 and let it sit for a bit. There could be a bit of rust holding it in. Then a little more energy with the hammer and punch and it SHOULD pop out. They are all roll pined in. Like was said above, check if the holes are lined up. Try punching from the bottom up.
  11. Malena
    Malena Member
    Dearborn, MI
    74 Comet
    That's very pretty! I have to ask, though: did you drive around to find a coordinating house to photograph in the background, or did you paint your house to complement your maverick?
  12. j miller
    Polson, Mt
    the house is one nearby and it is white although kinda hard to tell in that pic. i wish i owned it. it is over 100 years old and was one of the first in the town. it is now more of a museum.
    i have tried driving it up from the bottom and i think the pin is flared out. i have tried punching from the top and it did not move so i tried the bottom and i think the nail flared it out. i will try soaking it and get a bigger punch to try from the top.
  13. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    If your grinding away the nub, grind around the spring pin and you should be able to remove shifter. Not sure if your going to replace with a floor collar or not. Hope this is all clear. Good luck.
  14. broncoisl
    broncoisl Member
    Iceland
    1974 Comet 351W
    Very cool, specially like the green spark-plug wires:clap:
  15. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    J., you could still come to Ky. in 2007, the MCG is having thier first Gathering in Elizabethtown, Ky. in 2007. There will be some very special crowd pleasing events, more details to follow.;) C'mon up here and join in, have the most talked about 4 door. :D By the way cool car!
