a leap forward
Discussion in 'Maverick/Comet Projects' started by junrai, Jun 3, 2012.
  1. junrai
    junrai Member
    rancho cordova ca
    IMG_20170705_144149.jpg IMG_20170705_143751.jpg IMG_20170705_155320.jpg IMG_20170705_160630.jpg IMG_20170707_181611.jpg IMG_20170707_210840.jpg IMG_20170707_181841.jpg IMG_20170707_184303.jpg IMG_20170707_181617.jpg okay small update. took my gas tank out and had it acid washed and found a penny in the bottom of it :mad: and tons of rust well after getting it washed out I installed a new fuel line that I bent up from a role of 3/8 aluminum tubing added a new holley red electric fuel pump and pressure regulator along with the new hollry 650 double pumper carb after getting all of the leaks stopped except the sending unit (still gotta replace that) it fired right up. I still have more adjustments to do to it but it starts and moved under its own power again
    even my wife and son chipped in to help out. I have to admit my wife installed the sending unit after I got tired of fighting with it
    I also ordered the rear brake system for the new setup today from summit
    https://www.summitracing.com/parts/wil-140-7140-d
  2. junrai
    junrai Member
    rancho cordova ca
    parts are arriving its starting to come together IMG_20170713_141804.jpg IMG_20170714_120644.jpg
  3. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    I think I'd relocate the fuel pressure regulator up top where it's easier to access.
  4. junrai
    junrai Member
    rancho cordova ca
    well the fuel pump is supposed to be below the tank for gravity feed and the regulator is supposed to be as close to the pump as possible so with the limited space thats the only place to put it.
    Ive seen pumps way up front under the hood with pressure regulators a few inches away and Ive also seen a pressure regulator directly fitted to the pump and everything has worked out for everyone so I dont know if it makes much difference.
    I dont like my pump or regulator being where they are but that was the best place to put them according to manufacturers recommendations and it works so Ill live with it for now
  5. junrai
    junrai Member
    rancho cordova ca
    time for a couple of small updates
    Ive been dreaming away and stashing every extra dollar I can and always looking out for deals and now its paying off
    first update is that my engine is FINALLY making progress towards being finished. I saw the short block assembled today :yahoo:
    and recently I decided to sell a VERY clean maverick builder I was hanging onto for my daughter. decided I can find another one by time shes old enough to drive since shes only 11 now Ive got time :thumbs2:
    I posted the car on craigslist for $3000 obo and got an offer or two that got turned down and just before I was going to say welp I guess Ill keep it someone came by and said Ill take it for $3500 with a grabber hood after looking it over for MAYBE a whole 5 minutes tops. well it turns out that buyer is a fabricator by trade so I immediately started asking a million questions and after answering a few questions we decided he was going to keep his cash and build my chassis MY WAY for $6000 with the $3500 being the down payment :woohoo1: it was a done deal for sure after going to his shop and checking out some of the cars he was building for other customers including a 2000hp nova and a 800hp sleeper mustang notch back
    so now the engine is almost done my chassis and cage work is starting in about two weeks and he figures it will be done in a couple of months. the car is going in as is rolling complete and coming back completely DONE.
    the body will be removed from the frame once the frame rails are all tied together and cage is all built then the rolling chassis will go to powder coat then come back to his shop for the body to be installed
    :dancingpa:
    more updates as progress is made
    here are the pics of the car that I was hanging onto. as anyone can see this car is SUPER CLEAN but it went to a good home and I can HOPEFULLY find another one this clean if my daughter wants a maverick or comet when its time
  6. junrai
    junrai Member
    rancho cordova ca
    Construction is in progress pics will show the update this time
    Scary stuff
    Disclaimer the pictures are a bit graphic and might be disturbing to sensitive viewers
    Message_1563926659866.jpg IMG_20190724_194859.jpg Message_1563926682719.jpg IMG_20190724_194142.jpg IMG_20190724_194150.jpg
  7. junrai
    junrai Member
    rancho cordova ca
    only two years later the chassis is finally coming together its progress Ill take it I m excited to see the rest of it done
    72178482_2955354064515514_6287366130277285888_n.jpg 72725343_2955354261182161_726188620821561344_o.jpg 72114115_2955354491182138_9033602518948511744_o.jpg
    RMiller and Hotrock like this.
  8. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    That should help put all that power to good use....or lay down some serious marks on the road!
    junrai likes this.
  9. junrai
    junrai Member
    rancho cordova ca
    more progress is being made on the chassis and the front end is going to tilt when its done
    D259F6A0-929C-4BD7-BF26-9D214329D043.jpeg 15E13EA6-C201-40D0-AF44-8FDA8B9ECEFF.jpeg IMG_1823.JPG 8D9CA624-7D80-46E6-B74A-FCA581649F49.jpeg B62A275C-50D2-4C69-A456-7799464F8F96.jpeg
    yellow75, Hotrock and RMiller like this.
  10. mav1970
    Nice! Very nice!
  11. yellow75
    Tillamook Oregon
    A lot of times when I see people say what they plan on doing I just figure yeah it all sounds good but will never happen but in your case it really is . You will have one insane ride when you are done, keep up the good work and keep posting.
  12. junrai
    junrai Member
    rancho cordova ca
    its been a long road to get to this point but Im fortunate enough to have learned to make deals with people who have the skills I dont and no matter what not give up on the dream of this car. from time to time it stalls out due to not having money for parts or like everyone else sometimes life just gets in the way but I NEVER give up and know one day it will be done one way or another
  13. junrai
    junrai Member
    rancho cordova ca
    more progress and way better pics 78570692_3055615571156029_6168645833987194880_o.jpg 78130701_3055614901156096_1843406496088457216_o.jpg 75587549_3055615807822672_7347155847505510400_o.jpg 75412357_3055614054489514_233139487775916032_o.jpg 75635938_3055616124489307_3414589718619226112_o.jpg 76756833_3055615374489382_9127302513320525824_o.jpg 78057944_3055615157822737_7654727341859405824_o.jpg
    since this car is going to be driven on the street the cross bar behind the seats was curved back a little so I can have some adjustment to my seats once theyre in
    the 363 is finally making progress as well. perfect timing too
    the rest of the chassis will likely be done in the next week or so well see how things go.
    once the chassis is done were going to move onto everything else the car needs like
    the tilt front end
    installing the engine
    getting the pulleys figured out
    getting a transmission and getting it in
    custom headers built and installed
    buy the terminator efi kit with two throttle bodies and get them installed
    build and install drive shaft after balancing
    build and install fuel cell
    buy and install ignition system
    wire the entire car over
    buy battery box and install in trunk
    buy new tires install seats likely need to build custom tracks dont know yet
    take the body off of the chassis
    take the tail lights out
    remove whole dash and remove cluster
    take tons of stuff to powder coating
    firewall still needs to be finished
    crash bars are in just not pictured
    all of the sheet metal work for the floors should be done by next weekend
    car is coming out FANTASTIC!
    Im glad I found the fabricator Im dealing with hes way ahead of me any time I bring up anything thats not done yet.
    hopefully another update by next weekend
  14. yellow75
    Tillamook Oregon
    Great work, should be done by Christmas
    of 2021
  15. junrai
    junrai Member
    rancho cordova ca
    I WISH but dont think so. I figure I have another $20k for the car to be completely done
