A new small french
Discussion in 'Maverick/Comet Projects' started by scoubidou, Apr 3, 2008.
  1. scoubidou
    scoubidou Member
    West North of France
    Maverick V8; Toyota Supra Mk4 TT
    yes, my computer had broken down
    But I think of you...
  2. scoubidou
    scoubidou Member
    photograph of the motor
  3. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    Zoinks!
    Nice Scoubidou!
  4. scoubidou
    scoubidou Member
    Greeting,
    I often do not come, but I not you neglects not, a lot of job
    A question the friends, what oil do you put in your motor???
    And which oil quantity put on in your limp with (manual) speed.
    Thank you in advance.
  5. PaulS
    use 10w -30 oil in the engine and the manual gear box uses 85w-90 or straight 90w.
  6. scoubidou
    scoubidou Member
    ok, thank you.
    What oile quantity in the box of speed?
  7. PaulS
    You fill it to the level of the fill plug. That really isn't a joking answer - I just don't know the exact amount - I think it is between two and three liters.
  8. scoubidou
    scoubidou Member
    Ok thank you, i don't specified, il's a box 4 speed, if I could have precise quantity, this would be cool, thank you
  9. scoubidou
    scoubidou Member
    up up please :(
  10. tody
    tody Member
    cologne, germany
    the manual four speed transmission has a fill plug on the side. install the transmission in the car, open the fill plug and fill the transmission up - as much as you can get in until the fluid reaches the plug hole!
  11. scoubidou
    scoubidou Member
    ok, but you are the picture please...
  12. scoubidou
    scoubidou Member
    Good morning,
    For a long time I did not come
    a Little of news of Ford, it runs very well is in a lot of successes in France
    When I would find of time, I would put new photographs.
  13. chirt
    chirt Carlos Hirt
    Massachusetts
    Please do!
  14. scoubidou
    scoubidou Member
    I not much not to put photographs!?!
  15. Big
    Big Member
    North Idaho
    telechargez les photos sur un centre serveur d'image si votre avoir des issues et employez le lien de HTML pour signaler. Je propose http://www.imagevenue.com/ rapidement rapide et facile a utiliser. (y)
