A squeek at 170degrees
Discussion in 'Technical' started by stex97, May 12, 2006.
  1. scooper77515
    I am not sure if mine sqeeks at idle or not.
    Also, I have no carpet or any sound deadener, so like stex said, it really is hard to tell where the sound is coming from.
    I think I will drive around a little longer and see if it squeeks while moving, and exactly under what circumstances it sqeeks, and when it doesn't.
  2. sierra grabber
    sierra grabber Certifiable
    northern nevada
    :rofl:dont forget your cat. i use a screwdriver as a stethescope personally (just make sure the pointy part is on the car:D). see if it comes from the starter as it may be rubbing slightly and need to be shimmed or replaced. also make sure your inspection cover and trans/engine plate doesnt have a ding in it that is rubbing. just a thought:huh:
  3. stex97
    stex97 Member
    Seattle
    1977 Maverick
    So I did a little crawlin around when it was makin the noise and best place I could tell where it was comming from was the fuel pump, oil filter area. About a 1ft radius from that point on back to the transmission (that side of the 302). I listened in around the belts and nadda, listened all the way back on the exhaust lines and nadda. But its strongest point was that spot on back a bit (hard to tell on a direct area). I checked for rubbin lines, any dents along the plates of the oil pan/trans and for any missing/loose bolts and didnt see anything. I can slide under and take some pics if anyone needs a visual of what it looks like in those area's on this car.
    The mavs goin in to the shop in a couple days to get some rear-end work done, maybe I can pitch the question to them as well...:huh:
  4. 74merc
    74merc computer nerd
    1974 Comet
    I had similar problems, it was my alternator bearings.
    Fixed that, then I could hear the speedo cable... grrr...
  5. sierra grabber
    northern nevada
    is it a new fuel pump? do you have power steering?
  6. scooper77515
    Sierra...where you going with the power steering question?
    Might start to squeek when it gets hot? Or just drawing at straws as it sits on the same side as his squeek?
    Any history or experience with power steering squeeks at higher temps?
    I drove mine a bit yesterday, and the weather was nice and cool, and it only squeeked a little and periodically. When it is hotter out, it will squeek almost full time when warm, kind of a rattly-squeeking sound. Almost sounds as if I could grab the dashboard and it would stop, almost metal to metal...
    Not sure, at this point, if i have the same issue as stex, but the squeeks could be the same, as mine comes from the same side and has the same response to temperatures.
    Kinda wierd
  7. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    Try Putting Stp In Power Steering Pump Ford Tec Fix
  8. stex97
    stex97 Member
    Seattle
    1977 Maverick
    The fuel pump is new. I didn't think that a fuel pump/oil pump could make a noise like this, all-though i haven't heard a bad one before. Would there be anything that would do this between the engine/trans connection? Metal/liquid that would expand to cause some rubbing in that area?
  9. NAFORD302
    NAFORD302 Member
    SILEX MO
    Did You Try Starting It Up With The Belts Off See If Squeek Goes Away
  10. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Water pump bearings make squeaks and knocks.
    I know we are piling on the possibilities, but we are not there to hear it ourselves.
    The water pump would also surely be heat sensitive considering the job it has.
    Dave
  11. sierra grabber
    northern nevada
    yeah i was thinking to check the pump for squeaking:tiphat:
  12. ratio411
    ratio411 Member
    Pensacola
    My favorite stethescope is my 18" Snap-On 3/8" extension.
    Someone mashed the female end of it and now it won't go on a rachet. :mad:
    So I use the female end to my ear and the male end on the engine.
    Works excellent.
