absolutely frustrated
Discussion in 'General Maverick/Comet' started by BigDog41364, Jun 9, 2015.
  1. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    I have this ticking noise in the top end of the motor I cant figure out what it is, its driving me crazy. its the main reason I rebuilt the motor this winter while I was doing the MII install. it sounds like one lifter is ticking. here is what I done so far.
    new crank, rod and main bearings
    new rings
    new cam bearings
    new timing chain
    new oil pump
    new crane anti pump up lifters
    new crane push rods
    removed comp cam roller tip rocker arms and replaced with stock style rocker arms.
    adjusted the pre load from 1/2 turn to 2 1/2 turns no difference in tick
    adjusted guide plates
    beat my head on concrete floor till passing out ...still ticking
    it has 50 psi oil pressure at idle 60 psi driving
    have plenty of oil to the rocker arms
    Any ideas?
  2. mercgt73
    mercgt73 Member
    Exhaust leak at the manifold?
    Sometimes you can take a peice of vacuum line and hold one end to you ear and use the other end to try and find the noise. When you get close, it should get louder.
    Crazy Larry, 71gold and Krazy Comet like this.
  3. junrai
    junrai Member
    rancho cordova ca
    that could be a very good place to start it doesnt cost anything to check the exhaust gaskets. you could even remove the manifolds and double check the gasket is in good shape
    with all of that work to your front end I hope you have headers
  4. Acornridgeman
    Wisconsin
    Is the tick there with the valve cover off? I've seen a rocker tapping on a too close spot in the cover.
    Makes you crazy chasing down this stuff ................ :49:
  5. Krazy Comet
    First thing I'd is try to locate the noise to a specific area... No use to look at dist if it's in rear of engine...
  6. rlbriggs7212
    rlbriggs7212 Member
    Grass Valley
    1972 Maverick 64 Fairlane 52 Henry J
    I had a tick noise in a 302 that wound up being the fuel pump. I verified it after I was towed off the Dumbarton bridge in Newark Ca, during rush hour traffic!
    RLB
  7. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    did you replace the valve springs or check them
  8. Rasit
    Rasit Member
    SE Pennsylvania
  9. junrai
    junrai Member
    rancho cordova ca
    never even seen such a thing before pretty good idea and not super expensive
  10. bkcha
    bkcha Member
    Pooler, GA
    71 Gabber
    From the list i dont see new cam??
  11. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    Does the tick increase with rpm? Does it go away at any point? If it does increase with rpm, does the tick match the rate of increase in rpm?
  12. Bryant
    check for exhaust leaks with stethoscope or a hose to your ear. i suspect you have done this but have to suggest it till you verify its been done.
    check for leaks around the spark plugs in the same method as above.
    the fuel pump suggestion above is good. it has a spring in the pump to keep the arm on the cam. the spring can pop out and cause a tick noise in the motor.
    the valve springs could have problem. they rotate in their seats. it may have an edge its clicking on.
    could it be a bad spark plug wire that is arcing?
    what heads do you have?
    using a mechanics stethoscope should allow you to zero in on the noise. i will use the metal probe they come with to see zero in on the noise if its in the motor. i will remove the probe to listen for exhaust leaks, vacuum leaks, and even arcing plug wires.
    can you make a recording of the noise and post it?
  13. 71gold
    I use...heater hose...:thumbs2:
  14. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    Electric fuel pump
  15. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    On or off same noise
