AC / Heater Fan Keeps Blowing Fuse
Discussion in 'Technical' started by rthomas771, Nov 16, 2014.
  1. injectedmav
    injectedmav Member
    Georgia
    I will see if I can get a pic for you. It's been a few years but if you are using the stock AC system, it's a worthwhile mod.
    It's a 2001 Taurus motor FYI if you get one from a salvage yard. Get the resistor and connectors and as much wiring as you can. The motor is mounted in a plastic housing that you can remove the torx retaining screw to separate the motor from the housing.
    I believe I used a section of exhaust tubing that I split and welded flanges that clamps the motor so I could mount to the same studs in the housing as the OEM motor. I had to clearance the housing to fit the bigger squirrel cage from the Taurus but it was a relatively minor amount and I used the Taurus resistor as well. I only use 3 speeds so I can retain the Maverick switch. I also recommend running a relay to bypass the switch for high speed.
    As of now I have to work on Dec 6, but if I can make it you're welcome to take a look at it.
  2. 71gold
    thanks...this sounds like something others may be interested in...:Handshake:
    sorry Jeff for taking your thread a little sideways...
  3. Krazy Comet
    With the new motor from Vintage Air the only mod necessary should be the relay...
  4. injectedmav
    injectedmav Member
    Georgia
    Very true. I did this mod sometime around 2004-05 when the replacement motor I bought developed the same bushing squeak after one season.
    Back to the original problem, if the motor isn't mechanically binding, the brushes and commutator in the motor may be burned. I have seen some issues lately with cooling fan and HVAC fan motors with excessive brush wear and /or material transfer causing the circuit to open. (some newer controllers are able to turn off the circuit when current is too high)
  5. BrewDaddyDave
    BrewDaddyDave Member
    Miami, FL
    1975 Ford Maverick
    I'm having the same issue. I hear a loud "chirp/squeak" when I turn the A/C to high and no air blows out. Sometimes it will blow others it won't. Now my fuses keep popping. The owner before me put in an aftermarket radio. Would I begin troubleshooting the fuse panel to make sure it's not heating up?
  6. rthomas771
    I forgot all about this thread. My problem was a loose blower motor ground wire. The ground screw fell out from under the dash but the wire was leaning against metal.
  7. Krazy Comet
    Noise in blower then popping fuse is a motor or blower wheel related issue...
