Addco rear sway-bar?...
Discussion in 'Technical' started by T.L., Jul 19, 2005.
  1. MavMark
    MavMark Mega Modifier
    Detroit Area, Michigan
    Indeed you are correct. That photo was taken in 2003 well before the car was ready for prime time. I have since rerouted things a bit and completely insulated the pump and line with heat resistance foil and tape. I have also replaced the mufflers with flowmaster 50 series, replaced the rear brake line and replaced the rear shocks since then. :D ;)
  2. Jason M
    Jason M Hibernatin for the Winter
    Wingham, Ontario
    1976 Ford Maverick
    i didn't see a maverick specific sway bar on addco.net....... is there a different one we use or are they just not listed on the web site...... or did I miss it
  3. Maverick Man
    California
    hey how much fun did you have getting that U bolt in the sub frame for the endlinks? :p
    theres gotta be a better design then that wouldn't you think? or did they change it since the late 80's? mine was a.... well you know what to get in!
    and overtime i ended up ripping the subframe right off with the endlinks.. had to weld them back up.. now they ain't comming off anytime soon!
  4. RabidCustoms
    I dont know about mark, but when I put the u bolts in mine, it was more of a pain to drill the holes than it was to install. overall it wasnt too terrible. that my my isolated experiance with it.
  5. bmcdaniel
    i didn't see a maverick specific sway bar on addco...
    It's there in the list under Ford, PN 264. Summit sells them for $150, PN ACO-264G.
  6. bmcdaniel
    Addco PN 264
    They also list that same PN for a 75 - 80 Granada.
