Aerospace Components / New disc brakes!!!!
Discussion in 'General Maverick/Comet' started by CometGT1974, Feb 25, 2004.
  1. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    Steve that is very cool!! I wish I would've been on here sooner, the first thing I noticed was the paint on your suspension pieces. I know that is expensive stuff. MAN I'm so looking forward to July!!
  2. bmcdaniel
    Are the '74 spindles that used Mustang II type disc brakes the same as later spindles that used Granada disc brake parts? My interchange manual stops at '74.
  3. Cleaver
    Cleaver Member
    MD
    Chel
    I want to see the paint in a wheelstanding flash photo while leaving the line at Farmington this year. Hope to catch you there sometime. Every little bit of weight off the front helps a lot when you are looking for traction like you are.
    Cleaver
  4. MaverickRunner
    MaverickRunner Member
    North Port Florida
    73 Maverick 302
    All I can say is the car and parts look just as good in person as they do here in pictures!!!
  5. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    For all those interested in what the bracket looks like...
  6. Maverick Guy
    Maverick Guy Maverick Enthusiast
    NE Ohio
    Wow, all I can say is . . . nice! (y) :cool:
  7. Maverick Man
    California
    thanks that helps. you using the stock nut to keep the bearings in right?
  8. CometGT1974
    Western NC
    74 Comet GT
    yep, using the stock nut and washer.....but had to use an additional washer for spacing......
  9. Maverick Man
    California
    i got it to fit.. i just grinded a U slot in the spindel nut and cut up the tin cover (or what ever the thingy is called) to make the pin go though. its a tight fit but i got it to work.
    i was also going to ask you if kit required you to wire lock all the bolts on the caliper also on the rotor as well (if your rotor is two piece). most have told me there is no need to wire lock the bolts only if your road racing. however the kit does say to do it but also doesn't say what kind of wire to use. (check out the pdf link) on page 5
    www.wilwood.org/ds247.pdf]pdf link[/URL]
    i put some stainess still brake lines on too. i'll post that on my old post about the brakes. and up date on some of the part numbers
    also another question.. should the disk brakes (non pwr) have the same peddle pressure as the drums (non pwr).. just wondering since this is like the first conversion i've done.
  10. Maverick Man
    California
  11. CometGT1974
    Western NC
    74 Comet GT
    [QUOTEi was also going to ask you if kit required you to wire lock all the bolts on the caliper also on the rotor as well (if your rotor is two piece).
    also another question.. should the disk brakes (non pwr) have the same peddle pressure as the drums (non pwr).. just wondering since this is like the first conversion i've done. [/B][/QUOTE]
    My kit did not require the use of the safety wire, it used locking washers and specified that red loctite be used and the bolts torqued properly. I used the stainless steel lines exactly like you did it. I'm not sure about the peddle pressure, I replaced the master cylinder and the peddle pressure is outstanding. I used the 1 1/8" bore master cylinder from Aerospace and it feels spectacular!!
  12. Maverick Man
    California
    hey thanks good info to have
    thanks
