Aftermarket Air Conditioning
Discussion in 'Technical' started by jtown77, Sep 15, 2015.
  1. jtown77
    jtown77 Member
    Arizona
    71 Comet
    I need some advice. I'm going to put a complete new AC system in the Comet. It's a 250 with AOD, non-AC car. I'm looking at Vintage Air, Old Air Products, and Southern Air. I can't find any reviews or info about which unit would be better to put in. I know the air box in the 70 Mustang is just like the ones in the Comet and Maverick.
    Anybody put one in their Comet of Mav? Any reviews out there?
    I've called one of the companies about compressor mounting bracket. Seems everyone only makes the one for 170-200, not the 250.
  2. 71gold
  3. 71gold
  4. cyclonewill
    cyclonewill Member
    SandSprings, Oklahoma
    I've got a Vintage air GenIV in my 69, with full serpentine setup off a fox mustang. My compressor set up will do no good for you, but I love the actual evaporator section.
    I have the adaptors to control the unit with the factory controls, and no one knows it's not stock unless the look under the dash.
    Oh, and it will freeze you out!
  5. rthomas771
    I have a 250 AC bracket that was made by Vintage Air for a 69 Mustang with 250 it is made from steel...not cast iron like the factory. I found a cast iron factory bracket at the junkyard to mount the Sanden compressor adapter. You can't use 170/200 brackets on a 250 because of different bolt hole locations.
  6. rthomas771
    I found the 250 compressor/alternator mount...its for sale. You will need to find bolts and adapter plate.
  7. jtown77
    jtown77 Member
    Arizona
    71 Comet
    Thanks for digging it out. Bolts aren't an issue. Do you have a pic of how it mounts, alternator on top or bottom? pm sent
  8. jtown77
    jtown77 Member
    Arizona
    71 Comet
    You have a 69, so no glove box? any other mods that had to be done?
  9. rthomas771
    Alternator mounts below the compressor.
  10. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    I have a full Vintage Air kit on mine with a under dash compressor, everything went together well and their customer service is great.
  11. mojo
    Did u mean under dash "evaporator"? I didn't know there were any under dash compressors?
  12. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    Yes, I misspoke. I feel like you already realize this though.
  13. fuelish351
    fuelish351 Member
    San Jose, CA
    73 Maverick Grabber 2.3 Turbo
    There is a company that makes an electric A/C compressor you can mount anywhere, although it is pretty costly. Jegs also sells one for $1200-1500 555-51810.jpg
  14. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Will, what year Mustang did you use for your Vintage air setup? I am debating switching out everything from a factory ac Maverick to the non ac Comet, or going aftermarket.
  15. cyclonewill
    cyclonewill Member
    It's a 89-93 mustang accessory drive.
