Aftermarket floor shifter?
Discussion in 'Transmissions' started by lngroller, Jun 5, 2008.
  1. newtoford
    newtoford Member
    New Castle Delaware
    dont be scared by all the brackets, only one goes to a C4. the rest are Gm and mopar. it bolts to the bottom 2 bolts on the servo
    you can see the switch bolted to the side, idk what to say about reverse lights though.
  2. newtoford
    newtoford Member
    New Castle Delaware
    one issue is that you have to cut a piece off the transmission selector thing that the linkage rod bolts too and theres no way i can get any electrica powered cutting tool near it without dropping the header on the drivers side. which is also the one that required the engine to be lifted to bolt on
  3. 71gold
    my transmission guy told me you can take a :smash: and knock the outer ring off the yoke...:yup: that might give you the clearance you need...:Handshake
    ...Frank...:drive:
  4. newtoford
    newtoford Member
    New Castle Delaware
    i also dong think this shifter will be able to clear a bench seat since it has to be so far back. i'll take some measurments
  5. lngroller
    lngroller Member
    Richmond VA
    74 Comet 2dr 250
    The Hammer Shifter has a neat look also. I'm making a custom console and will be also fitting it with gauges like my 68 Shelby had, so I can make the console that hides a lot of the shifter box and makes it look like a console shifter. I'm early on looking for this but only have a few weeks (I hope)
  6. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    My car had one of those in it when I got it, but they apparently didn't have the bracket the shifter bolted to, because they hacked out a hole big enough for a four speed shifter and then bolted it directly to the floor pan. I also think they used a rod instead of a cable on it. I tossed it, filled the gaping hole with fresh sheetmetal, and then installed a Hurst V Matic shifter. It only required two 1/4" holes to mount it, and a 3/8" hole for the cable....much nicer.
  7. Jamie Miles
    Alto, GA
    I've had a few
    Does that shifter have a reverse lock out on it? It dosen't look like it. My dad had something similar in his Comet back in the 80's. His buddy was messing with the radio and accidentally knocked it into reverse at like 50 mph, the rear wheels basically locked momentarily before the engine stalled out and the car fishtailed on him. Could had very easily caused a wreck had other cars been around. I would not use an auto floor shifter without a reverse lock out.
  8. ford84stepside
    Berry Alabama
    Jamie, I think the way it is supposed to work is that you have to press the shifter down to put it into reverse, but it sure don't look like it would take much to knock it out of gear. My V Matic will not go into reverse unless you pull the trigger. You can bump it up into neutral, but not reverse.....
  9. newtoford
    newtoford Member
    New Castle Delaware
    yea you have to press the entire handle down to get it out of park or reverse.
