Aftermarket Steering Column
Discussion in 'General Maverick/Comet' started by MikeG747, Sep 6, 2010.
  1. mvw66gt
    mvw66gt Member
    Arthurdale, West Virginia
    71 Comet GT
    Just saw in the September Modified Mustangs and Fords that IDIT is making a tilt aftermarket column with Ford wiring connectors for 68-69 Mustangs. A little pricey if you ask me though. They quoted the chrome one for $676.00. Would be nice though if it had the key for the newer cars with the switch on the column.
  2. MikeG747
    MikeG747 Member
    Arkansas
    Your not hijacking the thread. This is all good information that will help me and hopefully others make an educated decision about doing a column swap. I would also like the tilt option. (y)
  3. car-nut
    car-nut Glenn
    conn.
    Thought I would update this just a little. I just ordered a new Ididit tilt steel column. I am going with the keyless, non chrome, 30" column. When I get it and start to mock it up I will post some info on it. I am going to try and adapt the lower firewall mount from my stock column to the new tilt unit that way it should bolt to the stock location there. I do see having to modify the upper column mount at the dash. Not completely sure how I will tackle that yet.
  4. 65 comet
    65 comet Member
    Colorado
    65 Comet Caliente Hrdtp, 65 2+2 Mustang Fastback 4 spd 53 F100 project 67 Ford 1 ton 4x4 project
    I've used a few Flamin' River columns but there again they are patterned after GM.
  5. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    how much did you pay for the column if you don't mind me asking.
  6. 65 comet
    65 comet Member
    Colorado
    They are $445 for the tilt steering column in paintable Machined S/S. It is for a floor shift and is 33 inches. You can find it on Flamin' Rivers site under 65 66 Mustang or 65 Comet. I will check and let you know the prices from a couple other places I have bought them thru.
  7. car-nut
    car-nut Glenn
    conn.
    The 30" Ididit was $365 to my door.
  8. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Car-nut, what are you going to do for the ignition switch? In dash like the 69.5's had?
  9. Mavaholic
    I want to put cruise control in my GT and looks like they can add it to any column. I just might have to buy one of those.
  10. car-nut
    car-nut Glenn
    conn.
    Yes, sort of! I am getting rid of the lower shelf and replacing it with a panel that will go from side to side of the dash. That is where the ignition, headlight, radio, wiper and possibly the heater controls will be. Stay tuned to my build thread for more updates on the dash soon.
  11. ford84stepside
    Berry Alabama
    Sounds sorta like a factory dash on 74-up, but with the wipers, lights, and heater controls added....
    I never understood why Ford put the heater controls on the left in our cars and the early Mustangs. Must have been to keep from the wife burning you out with the heater!
