AJE Suspension installed
Discussion in 'General Maverick/Comet' started by MikeG747, Aug 22, 2010.
  1. Brads72mav
    Brads72mav New Member
    California
    1972 maverick 1951 willys wagon
    not sure if this was asked or not but what oil pan are you running? foxbody style? and what rear suspension setup are you running? thanks! sweet car btw
  2. MikeG747
    MikeG747 Member
    Arkansas
    I am running the Moroso 20516 drag race oil pan. After destroying to rear ends I am now running a Fab 9 with 35 spine axels. Cal Tracks with split mono leafs. (y)
  3. compheads
    compheads Member
    Melbourne, Australia
    1972 For Maverick
    Tuff maverick, I can't decide if I'm going to full tube my mav or run a setup like yours? I'm going single turbo now. Did you get your car down the quarter yet?
  4. 5pointslow
    5pointslow Member
    Taunton MA
    1975 grabber
    after looking at mine ...looks like the previous over cut the towers back to far ....i dont even have the holes for the old setup anymore ..... i will take a pic later on . Not sure how to go about this now gonna pull my hair out
  5. 5pointslow
    5pointslow Member
    Taunton MA
    1975 grabber
    they have the struts in there just mounted to a hole in top of tower .....just doesnt look anywere near the stock location would be
  6. MavMan71
    MavMan71 New Member
    Elizabeth Illinois
    75 ford maverick
    Where do I call?
  7. MikeG747
    MikeG747 Member
    Arkansas
  8. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    You may want to look at the SN95-series Mustang geometry. Russ used the AJE crossmember but SN95 struts and spindles and ended up much closer to where you are now. Something to consider. I believe he cut out the entire setup, measured, and grafted into the Mav.
  9. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    What did you guys use to line the crossmember up? Obviously side to side I can measure and find the center but forward and back I'm just not sure?
