Alignment
Discussion in 'Drag Racing' started by mcknight77, Mar 30, 2016.
  1. mcknight77
    mcknight77 Member
    Boise, ID
    74 Mav drag car, 1970 Maverick, 1971 Bronco, 66 Nova, 67 Ranchero
    What are you guys running for front end alignment specs?
  2. 71maverickGT
    71maverickGT Member
    NY
    71 maverick gt
    I run my caster farther forward to put my weight more towards the rear and my toe slightly inward seems to work well. Stock bottom end 302 running low 12s at the track
    Richard Kuss likes this.
  3. mcknight77
    mcknight77 Member
    Boise, ID
    Thanks for the info. My alignment guy knew what I wanted and he dialed it in. Runs straight now.
  4. Rapture
    Rapture Member
    Crystal River, Florida
    1977 Ford Maverick (74, 74 Grabber, 73 Shells)
    did he give you a data sheet when he finished on the degrees he set everything to?
  5. mcknight77
    mcknight77 Member
    Boise, ID
    No, he did not. He has an old machine that doesn't give a printout.
    Rapture likes this.
  6. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    For a drag car you always want the top of your tires toed in slightly,this will make the car want to go straight.
  7. YellowStangDuan
    YellowStangDuan Member
    Arlington, Texas
    71 Grabber
    Originally the non-power steering cars use negative caster, that helps them turn easier. I changed mine to positive caster, makes it a little harder to turn at low speeds, but positive caster makes cars more stable at high speeds. Camber at 0 and toe to spec.
  8. mgabski
    mgabski Member
    1973 Maverick
    When you guys do your alignments do you guys raise the front of car to simulate ride height going Down track? Slight negative camber at normal high will make it close to 0 accelerating.
  9. groberts101
    groberts101 Member
    Minneapolis, MN
    Never heard of that one. Probably not a major issue unless you have softer rear spring rates and taller drag springs/shocks in the front. Ideally you don't want the front end 4 inches higher than the rear crossing the line and if it is?.. you likely need reduced front ride height to compensate and also some type of air dam to settle it back down for improved stability and less chassis/undercarriage drag. Better to shed some ET and make the car safer with higher downforce than lose even more and make it unsafe with too much underbody drag.
