alingment
Discussion in 'Technical' started by victor paz, Dec 23, 2004.
  1. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    Back in the olden days when I worked for an alignment shop we used a bubble level when the alignment rack was busy. Was'nt perfect but it got it close. On my Mav, I eye balled the alignment so the wheels were straight up & down and front to back looked straight. When I took it to get aligned I was only 1/8" off. With these new computerized alignment machines there should be no problems. Check your lower control arm eccentric bolt, maybe it has worked loose.
  2. victor paz
    victor paz PAZ
    California
    77 MAVERICK, 73 MAVERICK, 70 MAVERICK, HAD A FEW PARTS CARS
    strut-rod bushings?...
  3. 71gold
    "strut-rod bushings"
    vic.
    if you look under the bottom of your rad. support, you will see the end of the rods sticking out of the crossmember. there are bushings on each one...frank...
  4. victor paz
    victor paz PAZ
    California
    thats what i thought you were talking about , and there fine, thanks
