Alternator...Amps?
Discussion in 'General Maverick/Comet' started by Renton5, Oct 16, 2021.
  1. rickyracer
    rickyracer Member
    Central Nevada
    66 Stang, 68 Cougar, 72 Comet GT
    Just get a 100 amp alt and run a new wire of 4 gauge to the battery side of the starter relay. That will put direct charging to the battery. Your 50 yr old wiring was marginal 50 years ago. Old, corroded and insulation dry/cracked. Do it right the first time or have the joy of doing it again.
    mojo likes this.
  2. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    is the 3G still 3 wire or is it a one wire conversion?
  3. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
  4. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Here is the way mine is wired, for the most part same as above.
  5. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    did you have to modify the alt bracket? Did you buy new or get from another car?
  6. jasonwthompson
    Carrollton TX
    In my case it is a 72 with a 302 from the factory. My lower alt bracket attaches to the front of the alternator ear and fit without any issue. If your lower alt bracket attaches to the back of the alt ear, you may have to do some case and/or bracket grinding, but it will probably be minimal. I bought a new alternator from DB Electrical and picked up the factory style 3G alt connectors and fuse from somewhere I do not remember. I had read that some folks have a belt squeal problem when running the v-belt, so I replaced the smaller pulley with a 289 HIPO/Boss 302 alt pulley that is both larger diameter and deeper. I have never had a squeal or charging problem.
  7. bmcdaniel
    All depends on what voltage regulator they put in it. Mine is a one wire except I removed the yellow sense wire from the output terminal, added some length to it so I could connect it to the battery + terminal. That way it senses what the battery needs and isn't affected by the voltage drop in the charge cable. Made a noticeable difference in my overall system voltage.
    71gold, smegnl and TeeEl like this.
  8. Renton5
    Renton5 Member
    Van Nuys, CA
    1971 Maverick, 200 engine, 2dr
    Hi Everyone!
    Thank you very much for all of the responses to my alternator query!
    One question: What is the 1g, 2g, and 3g? I've not seen that designation
    for alternators.
    Bye,
    Daniel
  9. bmcdaniel
    1sr generation, 2nd generation, 3rd generation. Each one is a different design. 1G's (as originally used in Mavericks/Comets) were relatively low output, some of the 2G's were famous for catching on fire, 3G's have internal regulators and higher output. Some aftermarket companies put self-exciting regulators in them to make them one-wire deals.
    TeeEl likes this.
  10. Krazy Comet
    Dismal Swamp
    The 2G also has a internal regulator.
    Mostly the 2G is a 1G with internal regulator & plug on charge connector. Front half of case is same for 1 & 2G. Over time dirt, corrosion & vibration deteriorated connector contacts causing a overheating condition. With any alt service/failure, the connector should be replaced.
    TeeEl likes this.
