alternator not charging battery
Discussion in 'New Members Forum' started by devrin010, Jan 12, 2014.
  1. rthomas771
    Did you try what I suggested in post #7?
  2. devrin010
    devrin010 Member
    dixon
    73 maverick
    ya i checked the link and it was bad after the fuse so i just cut and solder the a new end on still no charge
  3. devrin010
    devrin010 Member
    dixon
    73 maverick
    ya i rev'ed it up and got the same voltage
  4. rthomas771
    Run a ground 12 gauge wire under the screw holding the regulator and the other end of the wire to the alternator ground terminal and see if that helps.
  5. schroensr
    schroensr knight Runner
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    Welcome to the site friend.:Welcome:
  6. MSmithPDX
    MSmithPDX Member
    Portland, OR
    By putting in a known good switch.
  7. devrin010
    devrin010 Member
    dixon
    73 maverick
    maverick wont start please gelp
    I can't get my 1973 maverick to start I tryed to re-gap the points and now I can't start it please help need it to start so I can sell it
  8. MSmithPDX
    MSmithPDX Member
    Portland, OR
    Go to 7-eleven and get a match book. Set the points using that and you'll be fine for life.
  9. devrin010
    devrin010 Member
    dixon
    73 maverick
    Thank you, It worked but its back fire when I step on it
  10. mav1970
    The ol' match book trick - always worked for me :thumbs2:
  11. devrin010
    devrin010 Member
    dixon
    73 maverick
    IV always had this back fire issue even before I messed with the points
  12. MSmithPDX
    MSmithPDX Member
    Portland, OR
    What motor and carb again?
    The most common cause of backfires after the fouled plugs, and resetting points comes from slop in your timing. You either have a lag in the advance that causes a little rich fuel before the timing pulls all the way out, or your valves are open at the sime time minorly(or majorly every few cycles).
    You can check for both situations by plugging in a vacuum gauge. For example, you can put a spark indicator on the #1 plug and watch for a flutter on the vacuum gauge needle when it indicates firing, and quick pendulum action lined up with the firing, often means both valves are open for a small amount of time, the depth of the flutter indicates how much time they are both open.
    The lag in the vacuum advance is also pretty obvious because the vacuum will drop incorrectly when you actuate the accelerator.
    Check over your vacuum routing, make sure you're on manifold vacuum and not ported vacuum (it's a personal choice really, but if you're carburetor is REALLY dirty it can have a huge affect on the ported vacuum). Maybe your vacuum pot on your distributor needs to be adjusted if it's adjustable, maybe it needs to be replaced. Could be loose springs in the distributor, or you just need to tweak the timing a little.
    A lot of simple things cause backfires, as well as a few majors. valves open at the same time, could be a major problem caused by cam wear or timing chain wear, or a minor problem because your distributor gear is worn and you just need to replace it.
  13. MSmithPDX
    MSmithPDX Member
    Portland, OR
    Also, I don't know what I'm talking about very well, so some of that is probably not 100% correctly explained. But should get you started on some testing procedures.
    And there are some guys who will probably relish the chance to correct the heck out of me, which is a bit of what I'm hoping for here for you.
