Alternator upgrade
Discussion in 'Technical' started by sam03rc, May 31, 2014.
  1. mavgrab302
    they have a natural finish one for under $187 too...
  2. sam03rc
    sam03rc Member
    gates county, nc
    1972 maverick 302 C4
    I see what you got now, except for the wiring and swapping the pulley out the 3g should a drop in unit. I'm going to pick it up tonight and see if it fits in there and if so then ill swap the pulleys over on it.
    Can someone answer this for me..... What is the real difference between the 1g and 3g I know everyone rants about how good they are and much worth the upgrade, but what's the real difference
  3. mercgt73
    Internal solid state regulator = more performance, less heat, longer life
    Internal fan shrouded in case = better cooling, longer life
    Bias ply tires did the job, but radials are just so much better. :yup:
  4. John Holden
    John Holden Member
    NJ
    Hey sam, let us know how it fits. I've heard some bracket mods may be required but that's just what I heard.
  5. sam03rc
    sam03rc Member
    gates county, nc
    Yea I'm going with the 3g if It fits, ill let yall know what happens and take some pictures.
    Has anyone done a serpentine belt swap? I know its kind of off topic but I'm almost thinking if its not going to cost too much do it now instead of swapping pulleys, the motor is right now a 289 ( getting it running for my dad he will need it back in a year but building a 88 302 40 over for when the time arises) all I'm running is water pump and alt.
  6. mojo
  7. sam03rc
    sam03rc Member
    gates county, nc
    ^^^^^ that one might be my back up if this one doesn't fit
  8. 71gold
    take the old one with you to compare...:yup:
  9. sam03rc
    sam03rc Member
    gates county, nc
    Alright guys here as some pictures of the fitment. looks like the plug will in on the inside towards the water pump but shouldn't be an issue. I'm going to go to the local parts store tomorrow and get them to swap the pulleys out for me. looks like if you want a 3G alternator upgrade from your local parts store this is the one for you in both 95 amp and 130 amp.
    I'm going to keep track of the pictures thru the install, and try to keep up with pictures along the way and make a little tech page on the swap, if anyone has a wiring diagram to help with this would be awesome.
    ( sorry for the mess shes been sitting for almost 2 years and doing alot of work under the hood)
  10. John Holden
    John Holden Member
    NJ
    Why don't you swap the pulley yourself?
  11. 71gold
    you can clock the plug to the outside if you like...:yup:
  12. sam03rc
    sam03rc Member
    gates county, nc
    I think it looked like my old alternator had the shaft that you needed the tool to hold it still but it didn't got them swapped over perfect and dropped it in the maverick and need to get a inch shorter belt along with space the alt out about 1/8-3/16inch to line up with my water pump and crank.
    How would I do that??
  13. mojo
    You could use a few washers to space it to where it lines up.
  14. mercgt73
    Sometimes you don't even need to completely separate the alternator, like he does in the video.
  15. sam03rc
    sam03rc Member
    gates county, nc
    Yea that's what I'm thinking i got some shims around here somewhere to fine tune it to get it closer.
    I'll check it out tomorrow when I have more time thanks guys
