Am I assuming right?
Discussion in 'Technical' started by maxsideburn, Mar 17, 2004.
  1. maxsideburn
    maxsideburn Member
    Lafayette, Louisiana
    1976 Ford Maverick (200CID I6/AUTO)
    wow that's really........strange.......
    Seeing as how factory sports cars usually have higher back ends than front ends I would have assumed that raising the back end a little would be MORE pressure onto the back giving better rear wheel traction.
    And as for safety......I don't understand what is so dangerous about the shackle setup....especially since it is a factory component.
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Actually that is not factory at all .... Here is factory ...
  3. maxsideburn
    maxsideburn Member
    Lol, I don't see the difference. So you're saying someone added this shackle type leaf spring setup to the car?
  4. jpollard
    jpollard Member
    Montana
    1977 Factory 302 Mav. 1970 Cougar Eliminator, 1975 302 Grabber, 1976 4door 200...and still looking
    Yep...there are not adjustment holes on an original.
  5. dmhines
    Cumming, GA
    Those adjustable shackles were made for two purposes:
    To jack a car up to make it look meaner or clear over size tires ...
    or to bring a car back up to stock height when old saggy springs drop it down ...
  6. maxsideburn
    maxsideburn Member
    That's interesting to know. In that case I guess I'll just keep it where it is.
  7. Craig Selvey
    "In that case" you should remove them and put factory shackles back on. Leaving those on the car WILL eventually tear up your frame rails and render the car useless.
  8. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    IF I were going to HAVE....
    ...to leave them on, I would take the sawzall
    and cut them off.
    I laugh like heck everytime I see them. They
    are totally unstable, I don't know why they
    are made.
    Listen to Craig. Replace them with stock
    shackles and get new springs or spring
    helpers, add another leaf or re-arch.
    Anything but those things.
    In fact, IF I still have a spare set, and I
    may have kept them, you can have them.
    I'll even pay the postage. I will look for them
    this Sat. afternoon.
    Good luck with your project.
  9. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    I thought using shackles went away with the '70s. Every car that I knew about with shackles eventually had leaf springs with no arch, a droopy, unstable rear suspension, and a soft, spongy ride. In short, they turn your performance car into a dud.
  10. Mavaholic
    Shackle lifts always were and always will be for the uninformed, (I'm being very polite). I grew up in the late 60's early 70's Muscle car era. Not one hot car that I ever knew or seen, had shackle lifts on them.
  11. Maverick Guy
    Maverick Guy Maverick Enthusiast
    NE Ohio
    Just another unsuccessful shackle story
    I got together with some friends this past weekend. I showed my one friend the Maverick calender and he really enjoyed looking at all the Mavericks and Comets. Back in high school we both had Mavericks, I had a blue 72' 2 door and he had a Sprint, so we started talking about the good old days.
    His Sprint had a shackle lift kit on it when he bought it. He hated it on his car, he hadn't had the car very long, and due to the stress caused by the extended shackles on the car it literally fatigued the metal that the shackles were attached to so bad, that after several unsuccesful attempts of repairing it he finally got rid of the car. Ripped right through the trunk! He said this weekend if it wasn't for the lift kit, he would not gotten rid of it. :(
  12. maxsideburn
    maxsideburn Member
    anyone have a picture of the factory equipment?
  13. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    dmhines posted a picture earler in this thread. Look back on page 1. I believe your reply was "LOL" that you didn't see the difference. :slap:
  14. maxsideburn
    maxsideburn Member
    wait.......I'm really confused.......are you guys talking about the whole setup? or just the bushings? please does someone have a picture from the same viewpoint as my original picture, but with stock parts.
  15. Craig Selvey
    Here is the factory set up.....just ignore the rust!!
