American Speedometer & Tachometer Cluster
Discussion in 'General Maverick/Comet' started by jmgford, May 30, 2012.
  1. John Holden
    John Holden Member
    NJ
    I'd like to add a tip to improve the instrument lighting. As you all know by now the three bulbs that light up the instrument cluster do not do a very good job. I was not happy with how dimly it was all lit up so i went to Advance Auto parts and bought three Sylvania LED 194 bulbs and installed them. Well not to be corny but the difference is "night and day". The give the perfect amount of illumination. It looks like the way that more modern cars are lit up. They're not too bright either, just right. They were a little tough to install into the bulb sockets but with just a little extra force than you would normally use to install a standard 194 they popped right in. The only negative to this is that they cost $10 each but for good dash lighting it is worth $30 to me.
  2. Mavman72
    How did I not see this post!?...I had Jack mod my cluster a while back...If you are hemming and hawing and dont want to pull the trigger on this mod... Just do it man! You wont be dissappointed. Jacks work is First class on these so stop waiting and debating...You know Ford should have done it...You know you want one...So what are you waiting for!!!!
  3. jmgford
    jmgford Member
    Iowa
    Thanks Pete!
  4. mercgt73
    Jack's modification is truly awesome. If I wasn't sticking with my Dixco hood tach, I would be all over it for sure. (y)
  5. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    PM sent about this.....
  6. jmgford
    jmgford Member
    Iowa
    Recently? If so, I did not receive it.
  7. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    You should have it now.....
  8. jmgford
    jmgford Member
    Iowa
    I have a cluster ready to ship and another one to do next week. I have been turning these around in about a week. After finishing this next one, I will build one more for a give-away at the MCG Gathering again. Then that will be it for a while. I have my Fairlane to finish up for spring and a lot of things to do for the upcoming Gathering, here in Dubuque.
    I will continue to build these for those who want one, but the turn-around time will be longer. For future ones, I will only ask for a deposit to start with and then the balance upon completion.
    Thanks again to all those who have already purchased one. :tiphat:
  9. John Holden
    John Holden Member
    NJ
    Aw quit being so selfish Jack and crank these babies out. Every maverick should have come with one of these from the factory! :dance:
  10. qpdcqp
    qpdcqp Davon
    Yuba City Ca.
    70 Grabber Maverick, 75 2dr maverick
    So are you still building them or making do it yourself kits? :camera:
  11. jmgford
    jmgford Member
    Iowa
    Yes, I am still building them.
  12. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    is there a link with the cost?
  13. qpdcqp
    qpdcqp Davon
    Yuba City Ca.
    Same question for me. Also what dose it all include?
  14. jmgford
    jmgford Member
    Iowa
    I have PN'd both of you.
    Thanks.:tiphat:
  15. bLaH_hA
    bLaH_hA Member
    jacksonville, fl
    72 mav grabber(sold), 1970 maverick grabber clone
    Do you still have any clusters? I hope I am not too late.
