...another 8" rear disc brake mock up...
Discussion in 'Technical' started by 71gold, Mar 19, 2012.
  1. groberts101
    groberts101 Member
    Minneapolis, MN
    All those parts should handle that usage scenario just fine so long as you're mature about the way you drive the thing since that's what they were designed for.
    You can beef all those parts up if you really wanted to.. but a lower torque/rpm limited mild 302 would not really tax them hard since they were all originally used with V8's anyways. Good luck with it all
  2. WesCoaster71
    WesCoaster71 Member
    california
    1971 ford maverick A.O.D trans 302 5.0 cu
    The car was originally a i6 but im just guessing its a 8
  3. 71gold
    yes...:Handshake
  4. WesCoaster71
    WesCoaster71 Member
    california
    Its 4 lug in the rear... I want to make it five lug and what all should i need to build it up
  5. 71gold
    a stock 8"rear end, 5 lug 3:00 gear will be good...:Handshake
