Another AOD question
Discussion in 'General Maverick/Comet' started by x72COMETx, Dec 26, 2016.
  1. x72COMETx
    x72COMETx Member
    Vallejo CA
    Hello all,
    I was thinking of swapping out the c4 to an AOD and was wondering what all is needed to make the swap, also is it possible to use the stock floor shifter
    TM74 likes this.
  2. 71gold
    I used a stock Maverick floor shifter with my first AOD swap.
    AOD crossmember
    TV/TC bracket - SRK-4000 -
    TV Cable - KD-2AODHT Throttle Cable-TC1000U
  3. modmav
    modmav Member
    Jamestown ND
    when I was looking into using an AOD, my tranny builder said he could set it up where the cable is not needed, he has done several that way, not sure how many know how to accomplish that but he said it will run cooler and handle more HP and can be set up for 1-2-3-OD. not sure how that is done either, unfortunately my 69.5 has the small tunnel and would have been too tight.
  4. Krazy Comet
    The AOD quadrant only has six positions, has to be done with modified or custom valve body... Lentech valve bodies make the O/D on/off switchable, then there is room for PRN123... For not using the TV cable probably was going full manual valvebody... The one I had in my Bird(I modded valve body) didn't need the cable but it did shift early without it, so I kept it in place...
  5. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    The Lentech is a Great OD Transmission. I ran a performance unit in the 74 Comet which is in Europe now .. I had it set up with an ' Electric Shift ' with a rocker-switch and a light on my console. Just flicked the switch and I was in business and the light let me know I was there . Highly recommend it ! I had a ' Hammer-Shifter' also everything worked fine.
    Cometized
    (Chip)
  6. modmav
    modmav Member
    Jamestown ND
    he makes mods to the valve body and he mentioned pressure mods thats all I recall, I think was done using stock valve body. I did ride in a vehicle with one of them and was very impressive but now that I think about it probably only has the six positions all I was interested in was no TV cable
  7. 71gold
    same here...loved it.
  8. 71Mavrk
    71Mavrk Member
    Nevada
    Don't order an AOD rear trans mount. It uses the C4 mount.
    Micah
  9. Krazy Comet
    Yeah I have one of those trans for my T-Bird, the regular/premium switch used with the half motor will become the O/D on/off sw...
  10. x72COMETx
    x72COMETx Member
    Vallejo CA
    If I was to use the stock shifter that means on the stock shifter housing
    D=OD
    2nd=D
    1St=2nd
    Is this correct?
  11. Krazy Comet
    No, 1st = 1st, unless modded AOD has no manual 2nd..
  12. x72COMETx
    x72COMETx Member
    Vallejo CA
    Ok so it's 1st gear then skips right into drive?
    Sorry about the question I don't really know a lot about transmissions in general
  13. Krazy Comet
    Yep, you got it...
  14. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Tom,
    I have to do the same thing on my Bird. Did you buy a whole Lentech tranny or just one of their valve bodies?
  15. Krazy Comet
    I bought the trans from a friend that did buy the VB from Lentech & had a performance rebuild done by a shop over in Newport News...
