Anybody know of some hi-temp epoxy or filler?
Discussion in 'Technical' started by dmhines, May 29, 2007.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Maybe I bought these from you! :) ...
  2. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    No problem. I'm sure it will look great.
  3. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Maybe....
    ....should we leave positive trader feedback just in case? :thumbs2:
  4. littleredtoy
    littleredtoy Seth
    '74 Comet GT
    Hijack warning...
    ...I have never noticed the clip in the center of the cowl/firewall joint
    holding that vacuum line. Do you know which line that is?
    Seth
  5. Mavaholic
    If its an automatic, probably going down to the modulator valve.
  6. dmhines
    Cumming, GA
    It is an automatic ...
  7. Craig Selvey
    goes to the modulator valve. My car has one too.
  8. dmhines
    Cumming, GA
    Well the local shop wanted $175 to ceramic coat the exhaust manifolds. Instead I picked up some Eastwood Cast Iron Manifold Coating for $25. Paint it on and then run the engine for 20 minutes to make it permanent. I put the first coat on .. and have to wait 24 hours for the second coat ....
    Notice the engineering numbers and date codes .. these manifolds came off an October 1970 Built Comet ... Date codes are September 11, 1970. Comets got 302 engines 2 months before Mavericks did ..
  9. luckyirishpride
    luckyirishpride "Youngest Comet Owner"16!
    Southern California
    2x 1971 Mercury Comets Both V8s, P/S/, A/C
    Sheesh, you don't waste any time!!
    I just sent those out last Thursday and they are already made pretty!!
    For some reason... I don't know why that heat shroud looks different... I think it changed when it entered foreign territory! haha
  10. luckyirishpride
    Southern California
    O ya, Dan.... How do I know the date code for the manifolds... I want to check the other car/motor...
    Also, I don't think my other Comet has the sticker in the drivers door jamb, is there another way to tell build month besides that?
  11. dmhines
    Cumming, GA
    These manifolds are stamp 0J11 ....
    0 = 1970
    J = September
    11 = Day
    Without a Marti Report or Build sheet you can only determine the month from the door sticker .. but not the day.
  12. maverick75
    That looks awesome(y)
