anybody use a detroit locker?
Discussion in 'Technical' started by Clintd, Dec 6, 2010.
  1. john T
    john T Member
    coalinga CA
    72 maverick grabber
  2. Mavaholic
    Not if it is set up properly. I have no such problems with mine.
  3. maverick75
    Because we dont have trucks(we have car 8" rear ends not car/truck ones like the 9/8.8). Theres also air lockers but you never see those in cars. Theres a few Electronic ones, ive only seen one in a car before. But people prefer the automatic ones.
  4. john T
    john T Member
    coalinga CA
    72 maverick grabber
    but the Ox would be a good swap for someone that has a 9" or an 8.8" swapped in? or is there a car 9" and a truck 9"?
  5. jmgford
    jmgford Member
    Iowa
    I have a Detroit Locker in both my Maverick and my Fairlane and wouldn't have anything else. There is no objectionable noise, only a clicking when making slow turns. Not all Detroit Lockers are the same though. Both of mine have "hold-out" collars inside the two halves which prevent the cogs from repeatedly engaging and disengaging while turning. Without them, they clunk very loudly. I have a friend with a D.L. in his Maverick and after he complained about the loud clunking, I told him about the collars I put in mine. He took it apart and there was no provision for installing them. He removed it and put his Traction-Lock back in.
  6. Clintd
    Clintd Member
    Parlin NJ
    75 maverick, 89 Cougar (sleeper), 04 Superduty and a 87 Cougar
    I sent a message to the guy I bought the center section from and he said he is very sorry a d is sending me new springs and the cover for the spring block. So I'm going to stick with the track-loc for now. What I'm planing on doing is installing the new springs with a couple of nuts under them to shim them up and make it real tight. Is this what most of you are doing?
  7. darren
    I think I had a washer under each. It worked fine with new clutches.
  8. Bryant
    there is a shim behind the clutches. by puting a thicker shim in the clutchs you will get the higher brake away level. ive never shimed the springs in that style of tracloc and dont know how effective that is. if you cant find tracloc shims i have used 8" pinion shims and just cut the loops of the bolt holes off.
