Anyone familiar with this crate engine?
Discussion in 'Technical' started by dmhines, Apr 16, 2005.
  1. maverick1970
    maverick1970 MCG State Rep
    Missouri
    It is possible the engine might have integral teeth for a magnetic trigger distributorless ignition. I would guess the aluminum heads will take 40 pounds off the front
  2. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    315 Horse Power, nice.
  3. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
  4. Jason M
    Jason M Hibernatin for the Winter
    Wingham, Ontario
    1976 Ford Maverick
  5. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    Here's a nice stroker for a little more. 400 Hp
    ebay item number is 796733712
    I cannot figure out how to post a link on here, sorry
    clint
  6. FoMoDave
    FoMoDave Maverick Owner
    Cumming Ga.
    1973 Maverick 302 c-4,1971 Maverick 6cyl
    What are you going to do with the engine in there now ,I may want it. If I can help let me know. I do not know much about that engine but probly does not have fuel pump mounting on it. Not sure that fox body pan will work. I would look into Ford Racing Part#M-6007-A342
  7. maverick1970
    Missouri
    Gene Evans Ford in Union City, GA is offering free freight on crate engines. They have the M6007B51 in the ad for $2900. Looks like you might be 30 - 45 minutes from them. You might be able to get the engine cheaper if you pick it up and they don't have to pay freight. But there is still the tax issue.
    John Bleakley Ford also in Georgia is one of the largest volume Ford Racing dealers in the country. Their site gives a good breakdown of the engines.
    http://www.johnbleakleyford.com/frparts.asp
  8. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Thanks for the John Bleakley tip ... They have the M6007B51 engine for $2970 ... 320 horse and includes the e303 cam for producting HP and Torque at lower RPM's.
  9. maverick1970
    Missouri
    I am sure either of those two will have the engines in stock and will be able to tell you what needs to be swapped. You had concerns about the balancer which you can buy a new one from Professional Products for about $60
  10. FoMoDave
    Cumming Ga.
    M 6007B1 - check to see that it has threaded boss for clutch z-bar mount. M-6007-A342 400HP/390ft/lbs ,hyd roller ,10.0to1 ,GT-40 heads M-6049-X303 ,Victor Jr intake ,cast crank.
  11. dmhines
    Cumming, GA
    There are no roller blocks threaded for a z-bar ... I'll have to buy the $50 bracket that bolts onto the bell housing to adapt it ... no biggie ..
  12. maverick1970
    Missouri
    You could go to a performance engine builder like Keith Craft and get an engine built with the proper block.
  13. dmhines
    Cumming, GA
    I definitely want a roller engine and retro-fitting an early block just adds a ton of expense ..
  14. dmhines
    Cumming, GA
    Talk about bad luck ... The engine on my lawn mower died today too! Atleast I had more miles on the lawn mower!
  15. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    Yep. Like I said yesterday, "If it wasn't bad luck, you wouldn't have any luck at all.
    Depending on your mower, you can prorbaly buy a new cheaper than just the motor. Check prices here:
    htttp:/www.northerntool.com
    There's one in Norcross and they always have some engines on sale.
