Anyone have/made a steel cowl hood?
Discussion in 'Cosmetic' started by stockhatch, Jan 12, 2009.
  1. stockhatch
    stockhatch Re Member
    Boiling Spring Lakes NC
    '72 Grabber
    Cool deal, thanks for that information. I think I may go that route. I was thinking of drilling some holes along the scoop flange, then spot/plug welding and using seam sealer/panel bond to make a nice solid joint. Once that is done though, what would be a reliable way to smooth the seam on top between the hood and scoop? Seam sealer? Body filler? Would it hold up?
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    The man to ask that would be Rayzorsharp...
    Ray does top notch body work.
    I would think flexible body filler myself, but I don't do bodywork.
    Check with Ray.
  3. Fish OutOfWater
    Fish OutOfWater Brian
    Long Island, NY
    another type
  4. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    He got his from UNLIMITED.....its fiberglass and looks great on his car!
    So good it made it a supermodified :rofl: sorry inside joke
  5. j miller
    Polson, Mt
    is this closer to the look you are trying for? mine is fiberglass but i think it fits your look. if you don"t like hood pins you can always go with the flush mount twist and lock system.
  6. stockhatch
    '72 Grabber
    That's pretty close. If I have to run pins I'll just go with the CF from Maverick Man. I think Maverick Mans hood is the height, curve on the cowl, cowl width etc that i am looking for. Its just not steel :)
  7. stockhatch
    '72 Grabber
    Well, I say I would go with the CF hood, but it looks like he only does local pickup on the cowl hoods. Guess I'm stuck with steel regardless of what type.
  8. Maverick Man
    California
    what manifold do you have on the car? i have fit my grabber hood with a RPM Air Gap with a 1/4 inch spacer, holley carb with a 3-1/2 air cleaner with a drop base. clears fine. just watch what air cleaner nut you use.
    as for hood flying up. remember any race car should have hood pins for safety reasons.
    however on your honda and eagle. those hoods the latch is on the car side and the hook is in the hood. ours are differant becuase our latches are on the hood and the hook part is on the car. on those hoods the latch doesn't brake it is the hook that brake off. get it? ;)
  9. stockhatch
    '72 Grabber
    The car is in 1 billion pieces right now, but will eventually have either a Victor EFI or Victor Jr carb intake on top of a 351.
