Anyone know if Fuel Gauge reading is linear with resistance?
Discussion in 'Technical' started by dmhines, May 25, 2008.
  1. Mavaholic
    Nope. While your calculations are true, Your assuming the bi-metallic strip itself bends in in a linear motion with current. That is not true. It may take 4 times as much current for each quarter of deflection. Just to simplify the discussion and to illustrate the point, lets say it takes .1 amp to deflect it to 1/4 full. It would then take it .4 amp for 1/2 full, 1.6 amps for 3/4 full, and 6.4 amps to read full. I do not know what the actual values are, I just remember experiments from electronics school many moons ago.
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Aren't the gauges 5 volts? That is what the regulator is for ...
  3. Mavaholic
    Yes, I was just using 12v as an example in the equations.
  4. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I'm glad somebody understands all that!:D
  5. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
  6. PaulS
    OK,
    Run the tank dry. Then fill it to 1/4 on the gage - how much fuel in gallons?
    fill the tank to 1/2 - how mant more gallons?
    fill the tank to 3/4 - how many more gallons?
    fill the tank to the full mark - how many more gallons.
    You will find that the gauge does not work in a linear fashon.
