Anyone still running points distributor ?
Discussion in 'General Maverick/Comet' started by ike72com, Dec 10, 2019.
  1. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Dad taught me a good tip for points. Once you have them set run a piece of paper bag between them, then look close to make sure you didn't leave any fibers between. It's just aggressive and absorbs well enough to clean any little bits of oil from the points so they're totally clean and less likely to burn.
    mojo and ike72com like this.
  2. stumanchu
    stumanchu Stuart
    Portland, OR
    I have a points distributor, but the points are used as a signal for a TFI module and coil out of a early '90s truck. It is not as fussy when cold as I have no choke. I am going to do this conversion to any other point fired engine I ever get. Abit of wiring, a relay, and some good junk from pick & pull. http://www.gofastforless.com/ignition/tfi.htm
    Krazy Comet and ike72com like this.
  3. fredee
    fredee Member
    South MS.
    1971 comet
    Dual points for me. Had a pertronix kit for a little while until it failed.
    ike72com likes this.
  4. ike72com
    ike72com Member
    Charleston SC
    If you dont get your answer here might wanna go to any parts website. Plug info for both engine and compare numbers.
  5. maverick600
    maverick600 Member
    San Angelo, Texas
    From what I have read so far, the only difference is the shaft for the oil pump. Some older model engines have the 1/4" shaft and the later years had a 5/16" shaft. Still searching though
  6. mojo
    Where is heat riser in the heads? I only recall heat risers of the past in the intake w/rod hooked to carb/choke. I am going back a number of years on this one.
  7. Powerband
    Powerband Member
    NY's \H/
    AFAIH... The Early 144/170/200 had the smaller shaft and a smaller distributor bore hole in the block preventing early sixes from using the Duraspark series. All 250's use newer points or DS distrib'.
    ... believe the 1966 series (C6xx) - six blocks were first with new type (points) distributor that will accept Durasparks'. Also C6xx up blocks are 'dual drilled' for small bellhouse or Toploader 3.03 large bell trannys.
    D4ZE (1974) DS-II with OEM 13R degree advance slot ( 13 crankshaft X 2 = Max of 26 degrees centrifugal advance )
    haev fun
  8. Krazy Comet
    All factory heads have the heat riser opening between the center intake ports, heats intake for better fuel distribution/drivability. The external "pipe" heat risers to air cleaner came about due to lean emissions carbs.
    Heads on Comet are solid(sorry no pict).
  9. maverick600
    maverick600 Member
    San Angelo, Texas
  10. maverick600
    maverick600 Member
    San Angelo, Texas
    So I need to get my block number off the pass side and see what I have, this will tell me then if my engine will accept a 250 distributor...
  11. Powerband
    Powerband Member
    NY's \H/
    All Maverick inline engines 170/200/250 SHOULD accept same Duraspark and later Points distributors. Early six swaps sometimes used a sixties block replacements.
    Earliest six block I've seen in Maverick was in '71 / 170 , it is a C9DE (1969) casting block (in '63 Wagon), typical casting series for 4 main bearing 170's and seven main bearing 200's engine block . The casting number signals start date of specific casting series often modified until new casting series starts. My project build 250's are D2xx, D4xx, D6xx (72, 74, 76) and a D6DE (76) 200 currently.
    have fun
  12. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    Ike72com, I dug up the distributor but it looks like it maybe for a 351W and not a 302.
    AC37E872-64FC-4DDC-A222-B43C629D930C.jpeg 7B8C909E-5287-498E-947F-24E593076DC8.jpeg 3BB13A24-6027-45F5-8D08-F3CC175EE944.jpeg A6CB2D59-26C8-4789-B21B-3138157EB260.jpeg 5B65470E-98B0-4D18-82EB-D50A044EE8D7.jpeg
  13. ike72com
    ike72com Member
    Charleston SC
    BBMS
    i'll check those measurement when i get home today to see what you got.
    I appreciate you wanting to help. I pulled trigger and got in an order of parts from rocauto before holiday rush. Distributor was on that list and should be in sat or mon.
    I got christmas week off so gonna spend some intimate time in garage. My Christmas gift to myself is to hear engine purrrrr.
    mojo likes this.
  14. ike72com
    ike72com Member
    Charleston SC
    And if i remembered correctly a pencil fits tightly in 302 shaft. Fits loosely in 351 up to 460s
  15. Krazy Comet
    Ain't that a 351C dist? With dual points it'd worth $$$ on ebay.
