aod in a maverick
Discussion in 'Technical' started by JHodges, Jul 13, 2008.
  1. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    The ones in the F-250's must be of a different breed. The one in our '95 F-250 went well over 150,000 miles before it needed rebuilding. It is behind a 7.5L and it will pull a 16,000 lb trailer very well.
  2. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    Maybe... not sure.
    Your motor has quite a bit more power than the stocker 302 thats in ours tho, and ours is 4x4 w/ 31s on it. Underpowered usually means to transmission trouble eventually also.
  3. Andysutt
    Conway Arkansas
    1972 Comet GT
    Ok... good for you.
  4. Andysutt
    Conway Arkansas
    1972 Comet GT
    That's true, but when a transmission goes at at 40k miles, and again before 100k miles and I've seen it several times... I call them junk. They are weaker than AODs in many peoples views, and apparently they won't fit in a maverick anyways so no need of discussing them really.
    Also, like I said... it depends on the application. a 2 wheel drive truck with maybe a stronger motor will last longer than a stock 302 4x4 that sees lots of slow driving in the deer woods up and down hills. The AOD in another guys older truck lasted a lot longer than my gramps transmission and it went thru the same abuse.
    P.S... I wasn't trying to be scarcastic. It's just good for you that you haven't had one go out. I see how my post could be taken the wrong way.
  5. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    Thank you for making this statement it is what I have been trying to convey from the beginning(y)
